assign task value to a quad dummy device field
rayE
#1 Post by rayE » 15 Oct 2017, 05:02
I want to retrieve the WiFi level and assign this to one field of a quad dummy device. So i will set up a "sys info" task and un-tick the "send to controller" box. From my basic understanding i will then set up a rule that triggers once the "sys info" event has happened then assigns the WiFi level value to a dummy device using the "TaskValueSet" command.
Can someone help me out with the rule syntax to do this?
TIA
Ray
rayE
Re: assign task value to a quad dummy device field
#2 Post by rayE » 15 Oct 2017, 10:23
The answer is READ THE DOCUMENTATION :?
on WiFi#WiFiLevel do                                //On the WiFi signal strength event
TaskValueSet 2,2,[WiFi#WiFiLevel]           //Assign the value to field 2 in task 2
endon                                                     //End rule
rayE
#3 Post by rayE » 15 Oct 2017, 11:24
As a note! i do find the WiKi index page "lacking" in the ability to find specific information. Instead iv resorted to a google on the topic of interest.
But apart from that ESP Easy is SO NICE to use, well done guy's and gals :)
Ray
