ThingSpeak upate delay blocks system
s0170071
#1 Post by s0170071 » 28 Oct 2017, 10:12
Hi all,
I have a power meter sensor (MT681 EHZ, 3 values) reading every second. The result is also displayed in a webpage, also every second. That displays a real time power consumption in my home.
In order to push the values to ThingSpeak, I need to set the MessageDelay to 15 seconds. Its a ThingSpeak requirement.
When sending to ThingSpeak starts, the EasyESP pauses 15 seconds between the GET requests of each value- as it should.
Sadly, it also pauses everything else but background tasks (OTA and UDP) too. My sensor and the webpage do not get updated.
Q: is that really the intended behaviour or should'n we rather have a non blocking message queue ?
Q2: I did some more digging in the code. Seems like using thingspeak, each sensor transmits all vallues in one http request. The 15000 ms Message delay is therefore uselsee if I do not poll the sensor more often than 15s.
Is this setting then correct?
Device delay: 600s. ( Sensor gets polled every 10 minutes)
Message delay 0,
Send to controller (ThingSpeak). yes
rayE
Re: ThingSpeak upate delay blocks system
#2 Post by rayE » 29 Oct 2017, 15:54
I noticed this odd behavior as well. My fix was to NOT use a thingspeak controller. This is what i did.
1. sore the energy data in a quad dummy device.
2. Send the data with a SendToHTTP command. This can be set up in a rule that is triggered by a timer.
If you want ill post the rules i use for my setup tomorrow? Just ask
Ray
s0170071
#3 Post by s0170071 » 30 Oct 2017, 13:19
That would be nice. Thanks.
rayE
#4 Post by rayE » 02 Nov 2017, 08:45
Sorry for the delay.
My rules setup. I run these by sending event, SerialSend through the serial port, i guess you can run from a timer instead.
on SerialSend do
    SendToHTTP 184.106.153.149,80,/update.html?key=FIXDUF4VI6PUC8P0&field1=[FIELDS1-4#TotalL]&field2=[FIELDS1-4#FlowRate]&field3=[FIELDS1-4#TxBatteryLevel]&field4=[FIELDS1-4#NoFlowPeriods]&field5=[FIELDS5-8#ChargeStatus]&field6=[FIELDS5-8#RxWiFiSignal]&field7=[FIELDS5-8#CH7]&field8=[FIELDS5-8#CH8]
    event,Acknowledge
on Acknowledge do
    Pulse,12,1,100                                     //Turn LED ON for a period
    Delay 100
    Delay 100
    Delay 100
    Delay 100
My devices (only FIELDS1-4 shown) Notice that the dummy devices are disabled BUT you can still read and write to them. Disabling them stopped them from running every x seconds.
rayE
#5 Post by rayE » 02 Nov 2017, 08:49
OOps, correction.
s0170071
#6 Post by s0170071 » 07 Nov 2017, 07:51
Thanks for the info. There is - at least it seems - a simpler solution for me.
I want to post to thingspeak:
- one quad sensor (humidity / temperture / absolute humidity / ventilation)
- system info uptime
- system info free memory
Limitation on thingspeak is that you only send a message every 15 seconds.
I update the sensor values every 10 minutes (sensor delay). The thingspeak controller collects all four values from the quad sensor and sends them in one request. So no trouble here.
When I update the system info variables I simply choose 10 Minutes + 16 seconds and 10 minutes and 32 seconds. The occasions on which I run into the 15 seconds limitation are very rare then. It only happens every 6 hours for a single value.
If you set all sensor delays to the same value, only the first thingspeak request goes through- every time.
Users browsing this forum: Google [Bot] and 24 guests
