Two I2C devices with same address
s0170071
#1 Post by s0170071 » 13 Nov 2017, 09:31
Hi guys,
I would like to connect two SHT25 sensors, however, they do not provide the possibility to adjust their address.
How would I do that ? Found this
https://hackaday.com/2015/08/12/i2c-bus ... nal-touch/
but I am wondering is there some sort if soft I2C available ?
papperone
Re: Two I2C devices with same address
#2 Post by papperone » 13 Nov 2017, 19:53
You need an I2C multiplexer like TCA9548A but it's not yet supported by ESPEasy as it requires major rework on the I2C handling routines...
Drum
#3 Post by Drum » 13 Nov 2017, 23:08
Sometimes the best solution is to use a separate unit.
#4 Post by grovkillen » 14 Nov 2017, 07:47
Yes, as long as you have space for it I tend to use multiple units instead of packing one unit.
The downside is that my cheap APs are struggling with the increasing number of clients, not that the data transfer is rising but that the many clients is making the APs a tad unstable.
