ESP8266 readout by Domoticz stops
In my configuration Domoticz@Raspberry3 as controller reads the ESP8266s-with-ESPEasy.
Till approx. 2 weeks ago without problems related to continuity.
But now every day (rather randomly) at the side of Domoticz the read-out stops.
When directly calling the ESP8266s at their IP-addresses, I get response, telling me that the problem apperently is not at the side of the ESPs.
Practical remedy is simple, but rude:
when visually detected that read-out has stopped, via Putty I command to Domoticz@Raspberry a reboot.
Other people with comparable experience?
What could be the cause?
Better remedy available than manual reboot?
Re: ESP8266 readout by Domoticz stops
Did you maybe by mistake assign the same IDX to multiple tasks on the ESPs? Does a restart of the domotics session also fix the problem (other than reboot) ?Ton_vN wrote: ↑14 Jul 2017, 11:36 In my configuration Domoticz@Raspberry3 as controller reads the ESP8266s-with-ESPEasy.
IDXes are nowhere doubled.
Restart of Domoticz (such as after an Upgrade) is not a 100% sure remedy for a 'stuck' read-out.
Reboot 'on purpose' sometimes helpts, but not 100% either .......
Looking slightly longer, the reason may be simple [but
solution may be different story].
For the ESP8266s the Wifi RSSI has some variation over the day, but for the 'weak' ESP8266s the Wifi RSSI is reported to be < -85dB.
That may be too low for reliable Wifi-contact with the router in an environment which is crowded with Wifi-communication.
The ESP8266-controller (= Raspberry3) sits (for optimal positon of the RFLinkGateway relative to the 433MHz-network) also remote from the router, and for the ESP8266s it communicates over WiFi (through the router).
The Wifi-repeater should fill the 'holes' between ESP8266s, Raspberry-controller and router, but apparently that is a weak element in the WiFi-network.
That reboot of the Raspberry usually re-establises communication between the Raspberry and the ESP8266s may be a sign that the Wifi-route between Raspberry and router is the 'weak link'.
Possible remedies[?]:
1) Reposition the Wifi-Repeater and/or the ESPs and Raspberry (least effort, but try-and-error & compromisses)
- Result 170730: shifting the repeater => improved some ESPs + Raspberry, but lost other ESPs => present positions seem best-available (compromis)
- Result 170730: whether Repeater or WAP, the position of the device determines the coverage.
Adding an extra Wifi-device as WAP at remote position improves/extends/shifts the coverage, but still try&error/compromis.
- Conclusion 170730: Equivalent is the addition of a Raspberry (Zero) directly cable-connected to the router for handling of the ESPs and linked to present Raspberry-controller as Slave. Minor cabling change which eliminates the wifi-route between router and ESP-controller. "Work in progress"
- Conclusion 170730: 'if nothing else helps', but probably 3) already is most effective.
I see a coincidence that when the read-out of the ESPs stops also at almost the same time in Domoticz the operation of certain lua-scripts stops.
More reason to look at the Domoticz @ Raspberry3 and not at the ESPs, and to look as in idea 3) whether fitting an extra Raspberry specific for ESP-readout is a remedy.
After latest update of Domoticz to v3.8734 2 of the connected ESPs cannot be tricked to start again by reboot of the Raspberry-with-Domoticz.
The ESPs are not to blame, because in direct read-out I see them happily generating values.
Just a bright flash: check the IP-address on which that Raspberry communicates over WiFi with the ESPs!
And indeed, due to the update and related reboot, apparently the Raspberry had changed it's WiFi IP-address.
Re-aligned, and now they happily talk to each other.
Question now concentrates on a Raspberry-aspect: how to keep it operation on a fixed IP-address for WiFi.
[The cabled IP-address is not a problem].
Use your router rules to reserve a specific(fixed) IP to the MAC addr of the Raspberry WiFiTon_vN wrote: ↑14 Nov 2017, 19:10 After latest update of Domoticz to v3.8734 2 of the connected ESPs cannot be tricked to start again by reboot of the Raspberry-with-Domoticz.
Certainly helps to reduce the 'problems' by making a preset link in the router between MAC and IP:
thanks for the tip!
thanks for the tip!
Further improvement by fitting an extra WiFi-AP:
cable running from the main router to the AP covers the physical gap between the main router and the remote WiFi-AP
=> better spatial coverage and less effect to capacity than with WiFi-repeater at that distance 'listening-over-air' to the main router.
Users browsing this forum: Bing [Bot] and 14 guests
