text to lcd2004 (espeasy)
I will send text from domoticz to a lcd2004 on an espeasy board
commandArray = {}
commandArray['OpenURL'] = '192.168.0.144/control?cmd=lcd,3,1,ditiseentest'
print ('test ')
return commandArray
it works but in the logfile i see
2017-10-28 19:03:30.280 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.237 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.311 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.382 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.694 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.925 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
whats wrong in my lua script
thanks in advance
Ad
commandArray = {}
print ('test ')
return commandArray
thanks in advance
Ad
Re: text to lcd2004 (espeasy)
Add
to your URLshttp://
you mean this ?
commandArray['OpenURL'] = "http://192.168.0.144/control?cmd=lcd,3,1,ditiseentest"
print ('test ')
return commandArray
this gives the same error ...
print ('test ')
return commandArray
Hello ,
I have tried a lot
this is a lua script
It works but an error in the log file
Ad
I have tried a lot
I want to send data tot a lcd2004 displaycommandArray['OpenURL']= 'http://192.168.0.144/control?cmd=lcd,3,1,test'
who can give me the solution ?2017-11-20 18:30:06.213 Error: Error opening url: http://192.168.0.144/control?cmd=lcd,3,1,test
2017-11-20 18:30:17.230 Error: Error opening url: http://192.168.0.144/control?cmd=lcd,3,1,test
2017-11-20 18:30:26.203 Error: Error opening url: http://192.168.0.144/control?cmd=lcd,3,1,test
Ad
Remove "control" between / and ?
Like this http://192.168.0.144/?cmd=lcd,3,1,test
no then you came into de espeasy
The URL is fine.TD-er wrote: ↑20 Nov 2017, 19:30 Remove "control" between / and ?
the error is on the log from domoticz
Ad
the display is connected to a esp12 with espeasycommandArray['OpenURL'] = '192.168.0.144/control?cmd=lcd,3,1,ditiseentest'
print ('test ')
return commandArray
Ad
So is this Domoticz related then or what? The URL does update the display but Domoticz is throwing an error? Is any other commands that is sent from Domoticz to ESP Easy working but giving error in the Domoticz log?
Hi regarding this issue i'm facing the same errors. It doesn't make any difference if I make a lua script via the time script method I'll get the same error message.
There is also a strange issue if I try to display something on line 4 it's displayed on line 2.
I'm using a 4 x 20 lines display.
The display is connected to a esp12e with the latest ESPeasy v2.0.0-dev12. Domoticz is running on the latest stable version 3.8153.
2017-11-22 14:01:00.262 LUA: Pinging Henk
2017-11-22 14:01:00.379 LUA: Henk thuis
2017-11-22 14:01:00.382 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_ping_henk.lua
2017-11-22 14:01:00.409 LUA: Pinging Ursula
2017-11-22 14:01:00.443 (Ping) Light/Switch (Henk)
2017-11-22 14:01:01.457 LUA: Ursula niet thuis
2017-11-22 14:01:01.460 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_ping_urs.lua
2017-11-22 14:01:01.477 LUA: test
2017-11-22 14:01:01.477 EventSystem: Fetching url...
2017-11-22 14:01:01.477 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_display.lua
2017-11-22 14:01:01.525 (Ping) Light/Switch (Ursula)
2017-11-22 14:01:01.754 Error: Error opening url: 10.0.0.61/control?cmd=lcd,1,1,Domoticz_Sportweg
Henk.
Henk.
Users browsing this forum: Google [Bot] and 24 guests
