Sonoff S20 v1.3 Header
taylormia
#1 Post by taylormia » 22 Nov 2017, 16:06
The latest version 1.3 of the Sonoff S20 US does not have any way to remove the PCB for soldering a header to be able flash the device with ESP Easy. See pic at this link: https://imgur.com/a/Inn1A
Any ideas on how to put in a header without soldering?
ManS-H
Re: Sonoff S20 v1.3 Header
#2 Post by ManS-H » 22 Nov 2017, 16:21
Put the header as high as possible and solder from the top side. Or remove the plastic of the header and use only the pins.
mrwee
#3 Post by mrwee » 22 Nov 2017, 16:54
On the EU version you can put a flatheaded screwdriver where the PCB is 'fixed' in the housing and turn the screwdriver. The PCB comes out, and is easily put back by applying a bit of force
taylormia
#4 Post by taylormia » 22 Nov 2017, 16:58
Thanks mrwee. Can you post a picture of what you mean by "..where the PCB is fixed int he housing and turn the screwdriver"?
mrwee
#5 Post by mrwee » 22 Nov 2017, 21:53
taylormia wrote: 22 Nov 2017, 16:58 Thanks mrwee. Can you post a picture of what you mean by "..where the PCB is fixed int he housing and turn the screwdriver"?
If you look at the PCB you can see round white plastic going through the PCB. if you take the screwdriver beneath the PCB, right next to the white plastic, and try to force the PCB up, then it should come out.
https://imgur.com/a/gYDqO
#6 Post by grovkillen » 22 Nov 2017, 22:06
taylormia
#7 Post by taylormia » 22 Nov 2017, 22:12
I tried that but it does not come off. Do you think the Ground pin of the plug is actually soldered on to the PCB. See here:
taylormia
#8 Post by taylormia » 22 Nov 2017, 22:15
Thanks grovkillen. How would you use the pogo pins?
taylormia
#9 Post by taylormia » 22 Nov 2017, 22:41
I'm thinking that these Hammer Headers might work if I push the hammer ends in with some force: https://shop.pimoroni.com/products/gpio-hammer-header
Any opinions ?
LisaM
#10 Post by LisaM » 23 Nov 2017, 01:26
#11 Post by grovkillen » 23 Nov 2017, 06:13
taylormia wrote: 22 Nov 2017, 22:15 Thanks grovkillen. How would you use the pogo pins?
Here's some examples:
https://learn.adafruit.com/how-to-make- ... g/overview
https://bigjungle.net/blog/2015/5/6/rf-328-programmer
https://goo.gl/images/Fc3dLf
mrwee
#12 Post by mrwee » 23 Nov 2017, 21:23
taylormia wrote: 22 Nov 2017, 22:12 I tried that but it does not come off. Do you think the Ground pin of the plug is actually soldered on to the PCB. See here:
It does indeed look like it's soldered.
Justblair
#13 Post by Justblair » 29 Nov 2017, 15:47
You dont need pogo pins. Take the male header and solder your wires to the short side (the side that normally passes through the pcb.)
Push the other side of the pins into the empty pcb holes.
Press lightly on the side of the male header pins while you do the upload, the pressure will make more than adequete contacts...
When you are done remove the header pins.
taylormia
#14 Post by taylormia » 29 Nov 2017, 16:00
Thanks. I have actually taken the easy route on my S20 and have avoided headers, soldering etc. to get custom firmware flashed on it. I used the SonOTA script, which allows the flashing of Tasmota (sorry..not ESPEasy) firmware over the air on an out-of-the-box stock S20. I put together a guide for HomeSeer users on the integration steps where I describe how the OTA flashing happens. You can find the guide here: https://forums.homeseer.com/showpost.ph ... stcount=60
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot], Bing [Bot] and 11 guests
