Hi to all, I am trying to flash an ESP8266-01. I connect GPIO0 to GND, and toggle reset to ground and back, to put the ESP01 into flash mode. The blue led on the ESP flashes once, not twice. It used to flash twice, and I could send AT commands via a serial monitor, and it worked well. I connected to my router and got online. All good.
I am using a 5v 1A wallwart to power the ESP via LM1117 http://www.kynix.com/Detail/554237/LM1117.html 3.3v.
After trying to upload a program to the ESP via Arduino IDE, things changed. Now it flashes once, and I get no response to AT commands. No echo at all.
When I put the ESP into flash mode (GPIO0 low), I just get:
ets Jan 8 2013,rst cause:2, boot mode:(1,7)
When I toggle reset (GPIO0 high), I just get:
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
ets_main.c
I tried the following:
Clinic:esptool-master fedfull$ sudo python esptool.py --baud 921600 --port /dev/tty.usbserial-A50285BI write_flash -fm dio 0x00000 /esptool-master/v20ATFirmwareESP.bin
esptool.py v1.3-dev
Connecting...
Auto-detected Flash size: 8m
Running Cesanta flasher stub...
A fatal error occurred: Timed out waiting for packet header
I have Tried changing the baud to 9600, 19200, 57600, 74880, 38400, 115200, and 345600. The lower rates don't include the 'Auto-detected Flash size: 8m' or 'Running Cesanta flasher stub...'
On further testing:
Clinic:~ fed$ esptool.py --baud 115200 --port /dev/tty.usbserial-A50285BI flash_id
esptool.py v1.3-dev
Connecting...
Manufacturer: e0
Device: 4014
Clinic:~ fed$ esptool.py --baud 115200 --port /dev/tty.usbserial-A50285BI chip_id
esptool.py v1.3-dev
Connecting...
Chip ID: 0x001eb645
Clinic:~ fed$ esptool.py --baud 115200 --port /dev/tty.usbserial-A50285BI read_mac
esptool.py v1.3-dev
Connecting...
MAC: 5c:cf:7f:1e:b6:45
Clinic:~ fed$ esptool.py --baud 115200 --port /dev/tty.usbserial-A50285BI erase_flash
esptool.py v1.3-dev
Connecting...
I have rechecked my connection many times.
Does the blue led flashing once only mean anything? Any idea what I've done wrong.\
Thanks all guys.
Problem Flashing ESP8266-01
Re: Problem Flashing ESP8266-01
Flash mode:
Green TX, Yellow RX, Orange 3.3V, Black GND
Boot mode:
The unit pictured is the 1MB version, I haven't tried the old 512kB version.
Boot mode:
