Sonoff S20 v.1.3 2017.03.11 EU
zamzon37
#1 Post by zamzon37 » 26 Nov 2017, 07:37
I am trying to flash the esp easy firmware in the ESP
I am succeeded uploading the newest firmware with the esp tool.
But afterwards nothing happens, I tried flashing another version and restart several times with no luck.
I have tried with two different s20
It doesn’t make a WiFi hotspot.
Can someone please help.
Re: Sonoff S20 v.1.3 EU
#2 Post by grovkillen » 26 Nov 2017, 07:41
How long do you wait for the AP mode to kick in? Sometimes you may need to wait almost a minute.
If it still doesn't work, is this a fresh flash or is it a re-flash of a already ESP Easy-unit?
What programmer are you using?
Re: Sonoff S20 v.1.3 2017.03.11 EU
#3 Post by TD-er » 26 Nov 2017, 15:11
And what voltage does the programmer give on the V+ pin?
If that's > 3.3V, then you may kill the ESP device.
enesbcs
#4 Post by enesbcs » 26 Nov 2017, 17:42
zamzon37 wrote: 26 Nov 2017, 07:37 But afterwards nothing happens, I tried flashing another version and restart several times with no luck.
Did you try the 8285 type firmware with DOUT write mode?
astronomon
#5 Post by astronomon » 26 Nov 2017, 20:40
I had the exact same problem today and found a solution here viewtopic.php?f=4&t=3615&start=10
Use this one: ESPEasy_v2.0.0-dev12_normal_8285.bin
zamzon37
#6 Post by zamzon37 » 27 Nov 2017, 21:36
it helped flashing to the correct ESP chip.
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 19 guests
