Problems sending Data to Inluxdb
kickbutts
#1 Post by kickbutts » 25 Nov 2017, 12:49
Hi there!
First to say: ESP Easy is really great! Easy to use and stable.
But i am experiencing problems sending data to my Influxdb.
My ESP is running on v2.0.0-dev12.
Connecting to the network and getting sensor readings was not hard.
I have a working DHT22 which is proving good Data.
I am not able to send the data to my Influxdb.
I established a Generic HTTP Advanced Controller. HTTP Method and Header is not Problem. My Problem is the HTTP Body.
When the Body looks like this:
Flur value=%DHT22Temp%
Influxdb always returns the Error:
{"error":"unable to parse 'Flur value=%DHT22Temp%': invalid boolean"}
So I think ESP Easy is not parsing the variable "DHT22Temp" into the sensor readings. ESP Easy seems just send the String
which obviously cannot be inserted into a data field expecting an float.
So my Question: What is the correct syntax to send my readings.
kickbutts
Re: Problems sending Data to Inluxdb
#2 Post by kickbutts » 28 Nov 2017, 20:19
I made some test and the same problem if i use another variable.
When writing:
Flur value=%sysmin%
the same problem. Its not parsed.
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 15 guests
