I'm exploring RFLink as an option to add our living blinds to home automation setup. Right now the are controlled by a Vestamatic remote control (using 868 Mhz band).
These Vestamatic devices are not on the supported devices list for RFLink, and I'm unclear how I can use RFLink to control the blinds?
Can RFLink just learn the the remote control codes from the remote control unit?
Or does a developer needs to add Vestamatic to the supported devices (I would be happy to provision further required information)?
Hope you can point me in the right direction.
Thomas
Vestamatic blinds control
Re: Vestamatic blinds control
Maybe this should be posted in the RFLink forum part down the page, not in the ESPEasy part?
Better chances to get an answer there.
Agreed,
Thanks for the hint.
Thomas
Agreed,
Thomas
Doesn't matter, because i don't care if it's a Raspberry or Orange. uPyEasy is running on Armbian and if the Raspberry is running Armbian, it's going to run there also (probably since it can't test it).
บาคาร่าออนไลน์
บาคาร่าออนไลน์
Users browsing this forum: Anthropic Claude Bot [bot] and 17 guests
