SendToHttp keeps repeating call
edd--
#1 Post by edd-- » 11 Dec 2017, 10:29
I have a simple switch that needs to perform a webcall. The switch is a traditional wall switch, meaning it is ether on or off, only on a state change it should send the http call 1 time (the web call toggles the light state).
I have the internal pullup enabled and I use rules to manage the action.
Now, the problem is that when the ESP reboots this works fine, but after a while, the command call keeps being executed every second or so. Big issue since I have this installed in my 6-year old's bedroom and last night his light started going on and off all night :( Now that's torture ...
Does anyone know what the problem could be and how to solve it ? I already implemented rules because when using the web page provider I had the same issue ...
Thanks to anyone willing to help me out here !!!
my rules:
On System#Boot do //on boot
  timerSet,1,300
On Rules#Timer=1 do
 Event reconnect
 timerSet,1,300
On reconnect do
 WifiDisconnect
 WifiConnect
On switch1#Switch do
     SendToHTTP 192.168.77.94,80,/o_toggle.php?id=60
Re: SendToHttp keeps repeating call
#2 Post by grovkillen » 11 Dec 2017, 11:15
edd--
#3 Post by edd-- » 11 Dec 2017, 11:18
Well, in that case the web call wouldn't work right ? And it doesn't explain why it keeps on executing the same request over and over ...
So I don't see how this could be related ?
#4 Post by grovkillen » 11 Dec 2017, 11:47
What settings does the switch have?
edd--
#5 Post by edd-- » 11 Dec 2017, 12:39
edd--
#6 Post by edd-- » 11 Dec 2017, 12:41
#7 Post by TD-er » 11 Dec 2017, 14:12
You already said the internal pull up resistors are enabled.
But perhaps also add an extra resistor of about 10k as pull up and a small capacitor (100nF) parallel to the switch.
This will make sure the input is not triggered by external sources, or a bad contact in the switch.
Something like this:
N.B. the capacitor will add an extra delay to the switch.
If the delay is too long, lowering the resistor may help.
If the problem still occurs, but less often, increase the capacitor and lower the resistor.
Make sure not to use too much current in the resistor. 330 Ohm is 10 mA
#8 Post by grovkillen » 11 Dec 2017, 14:52
edd-- wrote: 11 Dec 2017, 12:39screen.png
You use the GPIO-2 for the LED as well as the switch... :roll:
edd--
#9 Post by edd-- » 11 Dec 2017, 15:16
ah ... my mistake, I thought this ment that the onboard LED would blink when the GPIO was grounded (when the switch was pushed), and strangely, it did look like that ...
You think this was the issue ? I now changed it to none, will test and see if this solves it.
Thanks a lot !!
edd--
#10 Post by edd-- » 11 Dec 2017, 15:26
Also interesting: I checked the logs to see when the problem started occuring, apparently it started exactly when my router rebooted (scheduled reboot).
#11 Post by grovkillen » 11 Dec 2017, 15:35
https://www.letscontrolit.com/wiki/inde ... figuration
GPIO2 is not ideal to use with a switch. Study the wiki and you'll understand why.
edd--
#12 Post by edd-- » 11 Dec 2017, 16:03
Thank you, so does this mean that you would advise me to use a different GPIO ? (since 2 is already connected to the onboard led) ?
#13 Post by grovkillen » 11 Dec 2017, 17:48
edd-- wrote: 11 Dec 2017, 16:03 Thank you, so does this mean that you would advise me to use a different GPIO ? (since 2 is already connected to the onboard led) ?
Yes, if possible.
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot], Bing [Bot], opensiteexplorer.org/dotbot [bot] and 16 guests
