Autonomous PID Heater controller
pic
#1 Post by pic » 15 Dec 2017, 11:34
Dear everybody,
This is my first post ;) (ESP Easy is very cool I use it everyday!)
I already use the level control function (DHT22 + Relay for Gaz boiler) with a simple web interface.
But I would like to play with PID control instead.
What is the easiest way to do?
Thank you in advance for your help!
toffel969
Re: Autonomous PID Heater controller
#2 Post by toffel969 » 15 Dec 2017, 13:43
pic wrote: 15 Dec 2017, 11:34 Dear everybody,
That really depends on your gas boiler. With Vaillant for example, it is possible to modulate the water temperature ( immitating an external temp sensor using pwm).
If you want to continue using a relay (on/off), a possibility is to use defined intervals of lets say 10 minutes. You then average the temperature reading over 10 minutes and then calculate a "burner on" time. All of this will have to happen in rules/dummy devices.
pic
#3 Post by pic » 10 Jan 2018, 09:49
HEllo, Thank you for your reply,
In my case it's not possible to modulate temperature there is only a dry contact input, your idea is interesting! I will try to implement it. I also have a lot of ideas but not sure how to implement, sorted by importance :
1 - I would like to schedule different temperature levels trough my little web page (html example attached) but I don't know how to link the selection field value to an ESPEasy variable. Can you please help me?
2 - Ability to detect when doors and windows are opened and keep heater off (how to detect fast changes in temperature?)
toffel969
#4 Post by toffel969 » 10 Jan 2018, 13:29
pic wrote: 10 Jan 2018, 09:49 HEllo, Thank you for your reply,
1. IMHO this task is a bit too much for the combination rules/dummy and would be better implemented in a controller (like Domoticz, FHEM, OpenHAB, you name it). I don't see a way to store the different times in a variable to access it with rules. The temperatures could be held in a dummy.
2. a) Hardware option, put a magnetic switch on doors and windows and include them in your rules (using multiple events to overcome the limitations concerning boolean nesting)
b) create a differential by means of a dummy with (in example task 7, with a double value, where Value 1 is the differential and Value 2 the last measured temp) -->
On Temperature#DHT22 do
Taskvalueset,7,1,[lastTemp#Dummy]-[Temperature#DHT22]
Taskvalueset,7,2,[Temperature#DHT22]
On difTemp#dummy >5 do
window has been opened
Users browsing this forum: Google [Bot] and 14 guests
