Simple text after change gpio status
nobody@all
#1 Post by nobody@all » 29 Dec 2017, 22:04
Hello!
How can I send simple text to controller after change gpio status. What i want? see the status of my door key. When door are closed- switch is pushed on (i want to see locked) when door are open switch is pushed off (i want to se unlocked)
what funktion should I use? switch?
do i need for this rules?
nobody@all
nobody@all
Re: Simple text after change gpio status
#2 Post by nobody@all » 01 Jan 2018, 19:47
ok. I spent all day trying to do something by my self and I am one step ahead.
Using switch input and some rules:
on wlacznik#status do
 if [wlacznik#status]=0
 gpio,12,0
 if [wlacznik#status]=1
 gpio,12,1
i can send via mqtt door status 0/1 (0-unlocked, 1-locked)
now the hardest thing for me - how can i send no 0/1 but locked/unlocked
My I please someone for help?
#3 Post by grovkillen » 01 Jan 2018, 20:01
nobody@all wrote: 01 Jan 2018, 19:47 ok. I spent all day trying to do something by my self and I am one step ahead.
 gpio,12,0
 gpio,12,1
You'll have to use the publish command. Please study the wiki on rules.
nobody@all
Re: Simple text after change gpio status [SOLVED]
#4 Post by nobody@all » 01 Jan 2018, 20:19
I did not think it is so simple :D
my all rules
on switch#status do
 if [switch#status]=0
 gpio,12,0
on switch#status do
 if [switch#status]=1
 gpio,12,1
on switch#status do
 Publish door,open
on switch#status do
 Publish door,closed
Thank You very very much :)
#5 Post by grovkillen » 01 Jan 2018, 20:21
Happy to have helped. :D
nobody@all
#6 Post by nobody@all » 01 Jan 2018, 20:54
last question.
When door change status locked/unlocked controller send two informations
from controller publish /%sysname%/%tskname%/%valname% /ESP_Easy/switch/status 0
and
door unlocked
How to set up to see only door unlocked?
edit
my bad :twisted:
i just erase topic and everything is ok.
#7 Post by grovkillen » 01 Jan 2018, 22:04
nobody@all wrote: 01 Jan 2018, 20:54 last question.
and
door unlocked
edit
my bad :twisted:
Just uncheck the "send to controller" in the settings for that device.
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot], Perplexity.ai [bot] and 12 guests
