*Solved *Rules not working
SoN
#1 Post by SoN » 03 Jan 2018, 11:10
Hi, i don't know why this code isn't working:
On System#Boot do
TaskValueSet,5,1,1 //Dummy-Task5 Para#SP
TaskValueSet,5,2,1 //Dummy-Task5 Para#HYST
endOn
On WW-VL#Temp do // WW-VL#Temp = DS18B20 Nr1  WW-RL#Temp = DS18B20 Nr2
   if [Para#HYST] = 1
   TaskValueSet,5,1,([WW-VL#Temp]-[WW-RL#Temp]) //Temp-Diff in Para#SP
      if [Para#SP] > 5
        gpio,5,1
        TaskValueSet,5,2,0
        timerSet,1,180
endOn
On Rules#Timer=1 do
    gpio,5,0
    timerSet,2,3600 //Pause 1h
endOn
On Rules#Timer=2 do
    TaskValueSet,5,2,1
endOn
If enabled, the esp webserver is no longer accessible. a permanent ping results in irregular timeouts. for brief moments the esp answers
Please can someone explain why?
Thank You
Re: Rules not working
#2 Post by grovkillen » 03 Jan 2018, 11:34
This section here is not allowed (nesting if statements are not possible in the esp easy rule engine... please study the wiki on how to overcome this "problem")
   if [Para#HYST] = 1
      if [Para#SP] > 5
        gpio,5,1
        TaskValueSet,5,2,0
        timerSet,1,180
SoN
#3 Post by SoN » 03 Jan 2018, 12:24
Thank you !!
is this ok?
for 1. try ... isn't working
On System#Boot do
endOn
if [Para#HYST] = 1
event <pump-on>
endOn
on <pump-on> do
if [Para#SP] > 5
gpio,5,1
TaskValueSet,5,2,0
timerSet,1,180
On Rules#Timer=1 do
gpio,5,0
endOn
On Rules#Timer=2 do
TaskValueSet,5,2,1
endOn
vader
#4 Post by vader » 03 Jan 2018, 12:35
Try this...
on Para#HYST = 1 do
TaskValueSet,5,1,[WW-VL#Temp]-[WW-RL#Temp] //Temp-Diff in Para#SP
if [Para#SP] > 5
gpio,5,1
TaskValueSet,5,2,0
timerSet,1,180
SoN
#5 Post by SoN » 03 Jan 2018, 13:14
as soon as I activate the rules the esp is not reliable anymore.
many timeouts.
it is a matter of luck if the web interface responds.
Load on Main-page is 75%, without rules 0%
is it possible that there is an endless loop?
without this line everything is ok:
do i need a delay for reading the ds18b20 sensors?
vader
#6 Post by vader » 03 Jan 2018, 13:28
You have
on <pump-on> do
Correct it to: on pump-on do
Or better change all to "pumpon" or "pump_on". Maybe the parser has a problem with the "-" in the name!
Normally sensors have a delay of 60 sec. Post a screenshot of yours....
SoN
#7 Post by SoN » 03 Jan 2018, 14:24
This works :
On System#Boot do
if [Para#HYST] = 1
event pumpon
on pumpon do
if [Para#SP] > 5
gpio,5,1
TaskValueSet,5,2,0
timerSet,1,180
On Rules#Timer=1 do
gpio,5,0
On Rules#Timer=2 do
TaskValueSet,5,2,1
Thank you for help
vader
Re: *Solved *Rules not working
#8 Post by vader » 03 Jan 2018, 15:30
Supi. U r welcome.
You can change this
into this
because it's just a simple subtraction, so we don't need the brackets ;)
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 17 guests
