MQTT sending a custom commands
arnoldg
#1 Post by arnoldg » 05 Jan 2018, 10:47
because i'm in the transit from http to mqtt i need some help in altering my custom plugin.
In this plugin i send a custom command dim with a value.
How do i do this with mqtt, is espeasy accepting custom commands programmed within the plugin or do i need to do program some work around ?
below is my working plugin
//#################################### Plugin 200: dimmer ##################################################
// Sample templates
//  Temp: [DHT11#Temperature]   Hum:[DHT11#humidity]
//  DS Temp:[Dallas1#Temperature#R]
//  Lux:[Lux#Lux#R]
//  Baro:[Baro#Pressure#R]
#define PLUGIN_200
#define PLUGIN_ID_200         20000
#define PLUGIN_NAME_200       "Dimmer 230V "
#define PLUGIN_VALUENAME1_200 "Dimmer"
boolean Plugin_200_init = false;
boolean Plugin_200(byte function, struct EventStruct *event, String& string)
  boolean success = false;
  switch (function)
    case PLUGIN_DEVICE_ADD:
        Device[++deviceCount].Number = PLUGIN_ID_200;
        Device[deviceCount].Type = DEVICE_TYPE_I2C;
        Device[deviceCount].VType = SENSOR_TYPE_DIMMER;
        Device[deviceCount].ValueCount = 0;
        Device[deviceCount].SendDataOption = false;
        Device[deviceCount].TimerOption = false;
    case PLUGIN_GET_DEVICENAME:
        string = F(PLUGIN_NAME_200);
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_200));
      case PLUGIN_INIT:
          Serial.begin(9600);
          addLog(LOG_LEVEL_INFO, F("Dimmer: Init OK "));
      case PLUGIN_WRITE:
        String log = "";
        String command = parseString(string, 1);
        if (command == F("dim"))
          Plugin_200_Write(event->Par1);
          log = String(F(" Set Dim level to ")) + String(event->Par1);
          addLog(LOG_LEVEL_INFO, log);
  return success;
// write
void Plugin_200_Write(byte Par1)
  Serial.write(Par1);
vader
Re: MQTT sending a custom commands
#2 Post by vader » 05 Jan 2018, 16:11
Why extra programming a new plug-in? All basic MQTT functions are on-board. You can setup this under "Controllers". What broker do you have?
arnoldg
#3 Post by arnoldg » 05 Jan 2018, 16:29
i have installed mosquitto on my rasp.
I selected in controllermqtt openhab.
but i don't want to use the gpio or pwm commands.
i need to send command dim with a value from 0 to 100.
the plugin i sended did this throug http, i wan't to do the same thing with mqtt.
vader
#4 Post by vader » 05 Jan 2018, 17:42
Ok, I'm not sure, but I mean all has to be done in the JSON format. So "dim" would be the topic, and the value of it the payload. What about the MQTT Import plug-in?
Users browsing this forum: Ahrefs [Bot] and 15 guests
