ESP Easy V2.0.0 Dev12; Rules not updating field
Bert'Ridder
#1 Post by Bert'Ridder » 13 Jan 2018, 17:47
For the check of the Central Heating is working, I want to calculate tyhe Temperature-Difference between the water out of the heater and the water coming back.
Yhis data I want to send to the Domoticz.
The temperatur of the water is measured wit DS18B20 Sensors. The difference will be calculated as a dummy_device.
What ever I try the Difference stays 0.
I made a small Rule:
on  Temp_2#Temperature_2 do
  TaskValueSet,5,1,([Temp_2#Temperature_2] - [Temp_3#Temperature_3])
What ever I try, the value of Device 5 stays 0. The output send to Domotics as JSON:
System
Build 20000
Unit 2
Uptime 1134
Free RAM 19408
Sensors
0
TaskName "Temp_1"
Temperature_1 20.62
1
TaskName "Temp_2"
Temperature_2 37.13
2
TaskName "Temp_3"
Temperature_3 34.81
3
TaskName "Temp_4"
Tapwater_4 28.25
4
TaskName "CV_Delta"
Delta_T 0
0
What is wrong?
Re: ESP Easy V2.0.0 Dev12; Rules not updating field
#2 Post by grovkillen » 13 Jan 2018, 18:17
Try another browser when you edit the rules.
Bert'Ridder
#3 Post by Bert'Ridder » 14 Jan 2018, 20:16
I've don that, but without result.
Nothing seems to work.
Changend the code a bit:
On  Temp_2#Temperature_2 Do
  TaskValueSet, 5,1,([Temp_2#Temperature_2] - [Temp_3#Temperature_3])
   If [Temp_2#Temperature_2] > 55   // When Watertemp > 53 degrees  LED on
     GPIO,2,0
   Else
      GPIO,2,1
   Endif
to check. Then the LED responds on the temperature.
So the rule-File is working,
Then i changed the condition of the IF to:
   If ([Temp_2#Temperature_2] - [Temp_3#Temperature_3]) > 5
          // When Delta Watertemp > 5 degrees  LED on
     GPIO,2,0
   Else
      GPIO,2,1
   Endif
But then nothing happens.
It seems that the calculation (subtraction) is not working.
Even:
TaskValueSet, 5,1,[Temp_2#Temperature_2]
is not giving any value to task 5 (CV_Delta.
wim16
#4 Post by wim16 » 14 Jan 2018, 22:34
I noticed that a dummy device is not updated when it's not enabled.
Do not know if that is as designed but maybe this is the cause of your problem too.
vader
#5 Post by vader » 16 Jan 2018, 22:19
I have checked the source code now and could not find the check for a entered square bracket. So I assume that only numbers (0-1) and operators (+-*/^) are allowed. NO task values!
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot], Perplexity.ai [bot] and 10 guests
