I am working on a project that once I have it working will grab temps from either domoticz or other esps(esp easy). currently I am using weather underground just for easy data parsing.
I need help...
I have the ENTIRE code working exactly as I want except the decimal points...
it grabs data from weather underground then parses it and puts it to a display a 4 digit 7 segment display driven by tm1637 driver. currently there is ALMOST no documentation on it but i got it working.
so it grabs data, parses it and then performs 4 tests on the data to see the temperature
if its single digit positive (8.5)
single digit negative (-4.4)
double digit positive (23.4)
double digit negative (-22.6)
based on the string length it returns a number if its that number it displays then parses the individual digits.
What I don't have working is the decimals on any of them. so its its 30.1C it displays 301 if its -9.5 its -95
I am using the TM1637.h from tubedisplay example because it has the degree symbol in it
there is another one TM1637Display.h which i don't believe has a degree symbol. If it does i dont know how to get it to turn on (help with that would be nice)
I have test code called test display that uses the TM1637Display.h library and it is able to light up the decimals
if i use the library i have it working on currently TM1637 i can perform a "tm1637.point(POINT_ON);" and it turns on the last 2 decimals of the last 2 digits. That command is supposed to turn on the colon for time however my display does not have that nor do i need that.
I can not figure a way to turn on individual dots even though i know they are working.
I tried integrating both libraries into the same code however when i initiate the last one, it takes over TM1637Display.h and then never gives back control to my original TM1637 .h. and even when i put some of the test code from the code below into my design it does not light up any decimal point
How can I get the decimals to turn on in the original TM1637.h or I can convert my code to TM1637Display.h but how can i display a degree sign . Id prefer to stick to what i have. Is there a manual (hex) way to call an individual dot that I am missing?
any help would be greatly appreciated
//setup tm1637 display
#include <TM1637.h>
#include <TM1637Display.h>
#include <stdio.h> /* printf */
#include <math.h> /* floor */
#define CLK 4//pins definitions for TM1637 and can be changed to other ports
#define DIO 5
TM1637 tm1637(CLK,DIO);
//TM1637Display display(CLK, DIO);
#include <ESP8266WiFi.h>
#ifndef min
#define min(x,y) (((x)<(y))?(x):(y))
#endif
#ifndef max
#define max(x,y) (((x)>(y))?(x):(y))
#endif
#include <ArduinoJson.h>
const char SSID[] = "-----";
const char PASSWORD[] = "----!";
// Use your own API key by signing up for a free developer account.
// http://www.wunderground.com/weather/api/
#define WU_API_KEY "-------------"
// Specify your favorite location one of these ways.
#define WU_LOCATION "--------------"
// US ZIP code
//#define WU_LOCATION ""
//#define WU_LOCATION "90210"
// Country and city
//#define WU_LOCATION "---------"
// 30 minutes between update checks. The free developer account has a limit
// on the number of calls so don't go wild.
#define DELAY_NORMAL (30*60*1000)
// 20 minute delay between updates after an error
#define DELAY_ERROR (60*60*1000)
#define WUNDERGROUND "api.wunderground.com"
// HTTP request
const char WUNDERGROUND_REQ[] =
"GET /api/" WU_API_KEY "/conditions/q/" WU_LOCATION ".json HTTP/1.1\r\n"
"User-Agent: ESP8266/0.1\r\n"
"Accept: */*\r\n"
"Host: " WUNDERGROUND "\r\n"
"Connection: close\r\n"
"\r\n";
void setup()
tm1637.clearDisplay();
tm1637.set(7); //BRIGHT_TYPICAL = 2,BRIGHT_DARKEST = 0,BRIGHTEST = 7;
Serial.begin(115200);
// We start by connecting to a WiFi network
Serial.println();
Serial.println();
Serial.print(F("Connecting to "));
Serial.println(SSID);
WiFi.begin(SSID, PASSWORD);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(F("."));
Serial.println();
Serial.println(F("WiFi connected"));
Serial.println(F("IP address: "));
Serial.println(WiFi.localIP());
static char respBuf[4096];
void loop()
// TODO check for disconnect from AP
// Open socket to WU server port 80
Serial.println(WUNDERGROUND);
// Use WiFiClient class to create TCP connections
WiFiClient httpclient;
const int httpPort = 80;
if (!httpclient.connect(WUNDERGROUND, httpPort)) {
Serial.println(F("connection failed"));
delay(DELAY_ERROR);
return;
// This will send the http request to the server
Serial.print(WUNDERGROUND_REQ);
httpclient.print(WUNDERGROUND_REQ);
httpclient.flush();
// Collect http response headers and content from Weather Underground
// HTTP headers are discarded.
// The content is formatted in JSON and is left in respBuf.
int respLen = 0;
bool skip_headers = true;
while (httpclient.connected() || httpclient.available()) {
if (skip_headers) {
String aLine = httpclient.readStringUntil('\n');
//Serial.println(aLine);
// Blank line denotes end of headers
if (aLine.length() <= 1) {
skip_headers = false;
else {
int bytesIn;
bytesIn = httpclient.read((uint8_t *)&respBuf[respLen], sizeof(respBuf) - respLen);
Serial.print(F("bytesIn ")); Serial.println(bytesIn);
if (bytesIn > 0) {
respLen += bytesIn;
if (respLen > sizeof(respBuf)) respLen = sizeof(respBuf);
else if (bytesIn < 0) {
Serial.print(F("read error "));
delay(1);
httpclient.stop();
if (respLen >= sizeof(respBuf)) {
Serial.print(F("respBuf overflow "));
Serial.println(respLen);
delay(DELAY_ERROR);
return;
// Terminate the C string
respBuf[respLen++] = '\0';
Serial.print(F("respLen "));
//Serial.println(respBuf);
if (showWeather(respBuf)) {
delay(DELAY_NORMAL);
else {
delay(DELAY_ERROR);
bool showWeather(char *json)
StaticJsonBuffer<3*1024> jsonBuffer;
// Skip characters until first '{' found
// Ignore chunked length, if present
char *jsonstart = strchr(json, '{');
//Serial.print(F("jsonstart ")); Serial.println(jsonstart);
if (jsonstart == NULL) {
Serial.println(F("JSON data missing"));
return false;
json = jsonstart;
// Parse JSON
JsonObject& root = jsonBuffer.parseObject(json);
if (!root.success()) {
Serial.println(F("jsonBuffer.parseObject() failed"));
return false;
// Extract weather info from parsed JSON
JsonObject& current = root["current_observation"];
const float temp_f = current["temp_f"];
Serial.print(temp_f, 1); Serial.print(F(" F, "));
const float temp_c = current["temp_c"];
//float temp_c = -6.5;
Serial.print(temp_c, 1); Serial.print(F(" C, "));
String temp_c_string = current["temp_c"];
//"-6.5";
const char *humi = current[F("relative_humidity")];
Serial.print(humi); Serial.println(F(" RH"));
const char *weather = current["weather"];
Serial.println(weather);
const char *pressure_mb = current["pressure_mb"];
Serial.println(pressure_mb);
const char *observation_time = current["observation_time_rfc822"];
Serial.println(observation_time);
// Extract local timezone fields
const char *local_tz_short = current["local_tz_short"];
Serial.println(local_tz_short);
const char *local_tz_long = current["local_tz_long"];
Serial.println(local_tz_long);
const char *local_tz_offset = current["local_tz_offset"];
Serial.println(local_tz_offset);
int temp_string_length = temp_c_string.length();
if (temp_string_length == 3)
Serial.println("its single digits positve");
float temp_c_single_p = temp_c;
int temp_c_single_p_add = temp_c_single_p *10;
int temp_c_single_p_2nd_digit = temp_c_single_p_add - (floor(temp_c_single_p) *10 );
tm1637.display(1,floor(temp_c_single_p));
// display.showNumberDecEx(0, (0x80 >> 2), true);
//tm1637.point(POINT_ON);
tm1637.display(2,temp_c_single_p_2nd_digit);
tm1637.display(3,18);
Serial.println(temp_c_single_p);
else if (temp_string_length == 4)
if (temp_c_string.startsWith("-"))
Serial.println("its single digit negative");
float temp_c_single_n = temp_c;
int temp_c_single_n_1st_digit = temp_c;
int temp_c_single_n_add = temp_c_single_n *10;
int temp_c_single_n_2nd_digit = temp_c_single_n_add - (ceil(temp_c_single_n) *10 );
tm1637.display(0,16);
tm1637.display(1,temp_c_single_n_1st_digit *-1); //to change later once resd
tm1637.display(2,temp_c_single_n_2nd_digit*-1);
Serial.println(temp_c_single_n);
Serial.println(temp_c_single_n_1st_digit);
Serial.println(temp_c_single_n_2nd_digit);
Serial.println("yay its double digit positive");
float temp_c_double_p = temp_c * 10;
int temp_c_double_p_final = floor(temp_c_double_p/100);
int temp_c_double_c_final_2nd_digit = floor((temp_c_double_p -(temp_c_double_p_final * 100))/10);
tm1637.display(0,temp_c_double_p_final);
tm1637.display(1,temp_c_double_c_final_2nd_digit);
//tm1637.display(2,16);
Serial.println(temp_c_double_p);
Serial.println(temp_c_double_p_final);
Serial.println(temp_c_double_c_final_2nd_digit);
else if(temp_string_length == 5)
Serial.println("its double digits negative");
float temp_c_double_n = temp_c * 10;
int temp_c_double_n_final = ceil(temp_c_double_n/100);
int temp_c_double_n_final_2nd_digit = ceil((temp_c_double_n -(temp_c_double_n_final * 100))/10);
tm1637.point(POINT_OFF);
tm1637.display(1,(temp_c_double_n_final*-1));
tm1637.display(2,(temp_c_double_n_final_2nd_digit*-1));
tm1637.display(3,16);
Serial.println(temp_c_double_n);
Serial.println(temp_c_double_n_final);
Serial.println(temp_c_double_n_final_2nd_digit);
//tm1637.display(0,16); negative sign
//tm1637.display(1,18); degree symbol
// Serial.println(temp_c_string);
// Serial.println(temp_string_length); //length of charaters in string to perform ifthen
return true;
test display
#include <Arduino.h>
// Module connection pins (Digital Pins)
#define CLK 2
#define DIO 3
// The amount of time (in milliseconds) between tests
#define TEST_DELAY 2000
const uint8_t SEG_DONE[] = {
SEG_B | SEG_C | SEG_D | SEG_E | SEG_G, // d
SEG_A | SEG_B | SEG_C | SEG_D | SEG_E | SEG_F, // O
SEG_C | SEG_E | SEG_G, // n
SEG_A | SEG_D | SEG_E | SEG_F | SEG_G // E
void setup()
void loop()
int k;
uint8_t data[] = { 0xff, 0xff, 0xff, 0xff };
display.setBrightness(0x0f);
// All segments on
display.setSegments(data);
delay(TEST_DELAY);
// Selectively set different digits
data[0] = 0b01001001;
data[1] = display.encodeDigit(1);
data[2] = display.encodeDigit(2);
data[3] = display.encodeDigit(3);
for(k = 3; k >= 0; k--) {
display.setSegments(data, 1, k);
delay(TEST_DELAY);
display.setSegments(data+2, 2, 2);
delay(TEST_DELAY);
display.setSegments(data+2, 2, 1);
delay(TEST_DELAY);
display.setSegments(data+1, 3, 1);
delay(TEST_DELAY);
// Show decimal numbers with/without leading zeros
bool lz = false;
for (uint8_t z = 0; z < 2; z++) {
for(k = 0; k < 10000; k += k*4 + 7) {
display.showNumberDec(k, lz);
delay(TEST_DELAY);
lz = true;
// Show decimal number whose length is smaller than 4
for(k = 0; k < 4; k++)
data[k] = 0;
// Run through all the dots
for(k=0; k <= 4; k++) {
display.showNumberDecEx(0, (0x80 >> k), true);
delay(TEST_DELAY);
display.showNumberDec(153, false, 3, 1);
delay(TEST_DELAY);
display.showNumberDec(22, false, 2, 2);
delay(TEST_DELAY);
display.showNumberDec(0, true, 1, 3);
delay(TEST_DELAY);
display.showNumberDec(0, true, 1, 2);
delay(TEST_DELAY);
display.showNumberDec(0, true, 1, 1);
delay(TEST_DELAY);
display.showNumberDec(0, true, 1, 0);
delay(TEST_DELAY);
// Brightness Test
data[k] = 0xff;
for(k = 0; k < 7; k++) {
display.setBrightness(k);
delay(TEST_DELAY);
// On/Off test
for(k = 0; k < 4; k++) {
display.setBrightness(7, false); // Turn off
delay(TEST_DELAY);
display.setBrightness(7, true); // Turn on
delay(TEST_DELAY);
// Done!
display.setSegments(SEG_DONE);
while(1);
