Hi ,
I am trying to build a high power LED dimmer using the ESP PWM but i have a problem PWM frequency is only 1khz this produces a buzzing sound since 1khz is audible tryed to add inductors but the problem still persists
Is there a way to increase the PWM frequency ?
Pwm frequency
Re: Pwm frequency
You will have to change it in the source code, but someone already made a pull request on git hub. So either wait or compile your own binAlan_37 wrote: ↑15 Jan 2018, 23:19 Hi ,
https://github.com/letscontrolit/ESPEasy/issues/575
Re: Pwm frequency
Thanks for your help toffel969
Re: Pwm frequency
I have a Problem with hard coded frequency because of noices that a PWM controled fan does if you don't bring it into an area where you cant hear it.
In arduino you do it like
what have i to do in easyESP coding?
Best reguards
Michael
void setup() {
TCCR1B = TCCR1B & 0b11111000 | 0x01; // Setzt Timer1 (Pin 9 und 10) auf 31300Hz
Best reguards
Michael
Re: Pwm frequency
