P029 MQTT helper works when disabled
wim16
#1 Post by wim16 » 16 Jan 2018, 21:35
Today I was surprised to discover that a P029 device switches it's gpio even when not enabled.
I checked the C002 plugin (which contains the P029 functionality) and it does not observe the enabled flag.
Is this a bug or as designed? If it is by design I think the enabled flag would best be removed from the settings webpage.
vader
Re: P029 MQTT helper works when disabled
#2 Post by vader » 16 Jan 2018, 21:44
Don't worry, it's just one of the many bugs.... :lol: Can you compile your own version? Then I can give you the solution....
wim16
#3 Post by wim16 » 16 Jan 2018, 22:11
Not yet, but I am going to try so I can learn more about espeasy.
It is not a bug that bothers me very much but my first idea would be to add it to C002.ino, is that the correct place?
vader
#4 Post by vader » 16 Jan 2018, 22:23
Removing it from the settings webpage is no good idea. The solution is in fact in _C002. The first riddle you solved! ;)
#5 Post by TD-er » 17 Jan 2018, 00:12
vader wrote: 16 Jan 2018, 22:23 Removing it from the settings webpage is no good idea. The solution is in fact in _C002. The first riddle you solved! ;)
Perhaps something worth a new issue on the githubs?
vader
#6 Post by vader » 17 Jan 2018, 09:01
I have no account on github. Maybe there is already an issue opened there.... :?:
wim16
#7 Post by wim16 » 17 Jan 2018, 10:48
I've just added an issue. Thanks for your help.
Users browsing this forum: Ahrefs [Bot], opensiteexplorer.org/dotbot [bot] and 19 guests
