So, I have ESP-EASY mega running on a sonoff like clone.
GPIO4 is connected to the relay.
I would like it to always turn on when the board is powered on.
Openhab is controlling this switch via MQTT too.
I tried setting the GPIO 4 default state to Output High but it does not seem to do anything.
I also tried using rules and system#boot, but it also did not work.
If the last message I sent over MQTT was to turn it on, then it will turn on after a power cycle (and around 6 seconds).
If the last message I sent over MQTT was to turn it off, then it will turn off after a power cycle.
It is confusing me since Openhab is not really continuously sending MQTT messages.
Any ideas what am I doing wrong?
Additionally, it is a bit surprising for me, but inside Pin buffer state I find:
Plugin Index/Pin Mode Value/State
1 4 output 0
1 15 output 0
I do not actually use Pin 15....
Having difficulties with Default State
Re: Having difficulties with Default State
Turns out I had 2 issues:
GPIO 4 is one of the 2 default I2C lines.
Removed that, and it was okay.
Now it turns on virtually instantly after turning on.
But around 5 seconds later, it retrieves the state of the gpio that was requested over MQTT.
Now to figure out why does that happen.
Solved the second issue. I had retained messages on my Mqtt broker.
Users browsing this forum: Ahrefs [Bot] and 15 guests
