Use Modul to set Voltage to Ports
ahlermi
#1 Post by ahlermi » 23 Jan 2018, 11:05
is it posible to use 2 outputports to set a voltage from 0 to 5 V or 0 to 3,3 V.
like 80% = 4V
did it somebody with existing modules?
budman1758
Re: Use Modul to set Voltage to Ports
#2 Post by budman1758 » 24 Jan 2018, 08:40
I don't think that's possible. Ports can use PWM but that does not change the voltage.
What exactly are you trying to accomplish?
#3 Post by grovkillen » 24 Jan 2018, 09:06
I'm planning on a guide using this PWM to Voltage unit.
It's not possible to go from exact 0v but almost. And top voltage is variable from 5v - 10v. But you need to feed it with minimum 12v.
Many LED drivers can dim on input 0-10v, also many electrical motors in ventilation systems can be controlled by 0-10v.
kimot
#4 Post by kimot » 25 Jan 2018, 10:42
If you have got enough free gpios, you can simply use something like this:
https://makezine.com/2011/02/15/dac/
With your 2 pins you get only 4 levels, with 3 pins 8 etc.
ahlermi
#5 Post by ahlermi » 25 Jan 2018, 18:46
because it is not possible to change internal timing of ESP8266.
My new idea is to talk to an arduino, give him 0 to 5V to convert it in percent and control pwm fan with the arduino, without noise.
4V = 80% speed
ahlermi
#6 Post by ahlermi » 26 Jan 2018, 11:30
Problem solved with PWM communication.
