I'm a beginner and I like ESP Easy. I started building automation with Domoticz. I encountered a problem with "Domoticz MQTT helper", there was no inversion of both GPIO and PWM. Furthermore, the PWM did not go to full state to the end, so I corrected it. I also wrote a DS2413 control library and edited the TM1637 library to work with MQTT.
Nice day quattro
more about on my webpage http://quattro.haje.cz
ESP Easy Domoticz MQTT
Re: ESP Easy Domoticz MQTT
If you have written things that may improve ESPeasy, you are always welcome to add a pull req. on the Github.
Today I modified the "Display - OLED SSD1306" library to support the I2C and SPI bus (i dont use HW I2C). In addition, the display communicates with Domoticz via MQTT,
Nice day quattro
Nice day quattro
I can't find your SPI Oled sketch.
Can you help me.
Funsailor
I know that you modify _P023_OLED.ino but I can't find your modifications!
Can you help me.
Funsailor
