Hi all,
I've build a Candle using a wemos d1 mini + a 12 led ring from Adafruit and ESP easy.
I would like to use it as notification light that will be used from Jeedom.
The candle is working fine and I would like to use a push button to switch ff the candle. The push button is connect to the ground and D4 (GPIO-0). My problem is that I can switch off the candle using Jeedom but not with the button itself.
Could anybody help me to build rules to switch off the candell? I start as follow without success :
On BP1#BP1=0 do
Candle,0
Thanks a lot
Neopixelcandel and rules
- budman1758
Re: Neopixelcandel and rules
The WIKI is your friend.
https://www.letscontrolit.com/wiki/inde ... rial_Rules
https://www.letscontrolit.com/wiki/index.php/Devices
Hope you find this helpful.
