Is it possible to Log a GPIO Pulse?
Humanoidx
#1 Post by Humanoidx » 26 Jan 2018, 06:06
Hey guys, I need some help... Im using my Espeasy as a high pressure aeroponics controller.
Previously I have been spraying my plants roots 1 second every 10 minutes using timers and GPIO on/off commands, Doing this I am able to log the GPIO with a Switch Device and send myself a notification through domotics if it has stayed on or off too long.
on rules#timer=1 do
if [system enable#status]=1
gpio,5,0
timerset,2,[Timer1#SprayON1]
on rules#timer=2 do
gpio,5,1
timerset,1,[Timer1#SprayOFF1]
I would now like to switch to an off time of 5 minutes and an on time of 500 mSec.
Ive tried doing this using 1 timer and a gpio short pulse as shown below.
on rules#timer=1 do
pulse,5,1,[Timer1#SprayON1]
Howeverrrr...... when I do this, it no longer logs when the gpio switches, it seems like the pulse command in rules doesn't send this info to the switch device, even if I bump up the pulse to 10000 msec.
Is there any way around this?, perhaps this can be an addition to the next build?
Many thanks for the development, I love ESP Easy.
Re: Is it possible to Log a GPIO Pulse?
#2 Post by grovkillen » 26 Jan 2018, 06:32
Please open an issue on Github. That is something that should be logged for sure.
toffel969
#3 Post by toffel969 » 26 Jan 2018, 11:21
Humanoidx wrote: 26 Jan 2018, 06:06 Hey guys, I need some help... Im using my Espeasy as a high pressure aeroponics controller.
on rules#timer=1 do
gpio,5,0
on rules#timer=2 do
gpio,5,1
on rules#timer=1 do
The normal pulse command is a blocking command. It doesnt react to anything during the time of the pulse --> it misses the input. maybe it is possible to adapt the longpulse command to values shorter than 1 ?
I just checked in the source. It should be easily possible to use longpulsevalues shorter than 1 sec. In _P001_Switch.ino
Thats the original code:
 if (command == F("longpulse"))
          success = true;
          if (event->Par1 >= 0 && event->Par1 <= PIN_D_MAX)
            pinMode(event->Par1, OUTPUT);
            digitalWrite(event->Par1, event->Par2);
            setPinState(PLUGIN_ID_001, event->Par1, PIN_MODE_OUTPUT, event->Par2);
            setSystemTimer(event->Par3 * 1000, PLUGIN_ID_001, event->Par1, !event->Par2, 0);
            log = String(F("SW   : GPIO ")) + String(event->Par1) + String(F(" Pulse set for ")) + String(event->Par3) + String(F(" S"));
            addLog(LOG_LEVEL_INFO, log);
            SendStatus(event->Source, getPinStateJSON(SEARCH_PIN_STATE, PLUGIN_ID_001, event->Par1, log, 0));
by removing the factor "1000", the longpulse should now take msec, rather than sec. Try to chang it to:
          success = true;
            setSystemTimer(event->Par3 , PLUGIN_ID_001, event->Par1, !event->Par2, 0);
change the source, compile bin and try with longpulse command . Suggested rule(you need NTP):
On Clock#Time=**:*0 do
longpulse,5,1,500
On Clock#Time=**:*5 do
longpulse,5,1,500
That should do the trick
Humanoidx
#4 Post by Humanoidx » 30 Jan 2018, 03:08
Thanks alot, that roughly works, a little delayed but at least its logging.
toffel969
#5 Post by toffel969 » 30 Jan 2018, 07:54
Humanoidx wrote: 30 Jan 2018, 03:08 Thanks alot, that roughly works, a little delayed but at least its logging.
Glad I could help. @ grovkillen: maybe this could be added to github any way. Do you see a good reason why longpulse should be in seconds rather than msec? If you need the length, just add 0s, if pulse lengths exceeds variable, use timer instead. What do you think?
#6 Post by grovkillen » 30 Jan 2018, 08:05
toffel969 wrote: 30 Jan 2018, 07:54
I think the reason is the timing, long pulse is "not that important" to end on exact 1.0000 seconds. Since the long pulse lets the rest of the loop carry on we might not know exactly when in the time span of a loop the long pulse will end. The pulse will halt everything else and wait for the mSecs to count up until reached target level. The long pulse is more of a "more than"....
I believe we should leave it as is until future releases. Or is it something we feel need to be added to the "future" milestone?
toffel969
#7 Post by toffel969 » 30 Jan 2018, 10:55
grovkillen wrote: 30 Jan 2018, 08:05
Maybe I didn't express myself clearly. I still think we need a pulse (where accuracy is very important) and longpulse command (that is non-blocking). I am suggesting we change the unit of time from sec to msec, so that one can use sub 1 values in a non-blocking pulse.
On a different note, I really think the pwm fade should be a non-blocking commmand (long pulse style), as fade times are almost always above 1 sec.
#8 Post by grovkillen » 30 Jan 2018, 11:24
Ah, I hear ya.
I will talk with psy0rz and TD-er about how to go about that.
#9 Post by grovkillen » 30 Jan 2018, 18:52
We think both these suggestions made by Toffel is logic and we'll add them to the 2.0.0 release.
https://github.com/letscontrolit/ESPEasy/issues/794
https://github.com/letscontrolit/ESPEasy/issues/793
toffel969
#10 Post by toffel969 » 31 Jan 2018, 07:37
grovkillen wrote: 30 Jan 2018, 18:52 We think both these suggestions made by Toffel is logic and we'll add them to the 2.0.0 release.
cool beans, thx :-)
Users browsing this forum: Anthropic Claude Bot [bot], Perplexity.ai [bot] and 17 guests
