send hex data to serial server ser2net
riker1
#1 Post by riker1 » 26 Jan 2018, 17:32
how can I send hex commands to the device?
defined device Serial server tcp 23
need to send : echo -ne '\xA1\x01\x01\xA2' | nc 192.168.0.10 23
Thanks T
enesbcs
Re: send hex data to serial server ser2net
#2 Post by enesbcs » 26 Jan 2018, 20:25
riker1 wrote: 26 Jan 2018, 17:32 how can I send hex commands to the device?
If you want to use the 5V Wifi relay, it is supported by the P165 Serial MCU controlled relay plugin, choose "LCTECH" when setting up the device, ESPEasy binary uploaded to this thread:
viewtopic.php?f=6&t=3245&start=50
riker1
#3 Post by riker1 » 27 Jan 2018, 09:02
enesbcs wrote: 26 Jan 2018, 20:25
Hi , thanks for this hint.
looks like I am unable to identify this device? too stupid or blind...
in R147 I do not see the Serial MCU controlled relay plugin nor in GIT version: mega-20180104
nor :GIT version: v2.0-20180113
How can I enable the P165?
serial Screenshot from 2018-01-27 09-01-25.png (85.16 KiB) Viewed 7715 times
enesbcs
#4 Post by enesbcs » 27 Jan 2018, 09:56
riker1 wrote: 27 Jan 2018, 09:02 in R147 I do not see the Serial MCU controlled relay plugin nor in GIT version: mega-20180104
1/ You can compile it yourself from github from the Plugin Playground:
https://github.com/enesbcs/ESPEasyPlugi ... Switch.ino
2/ You can use the pre-made binary attached to the first post of the thread, that i linked before:
viewtopic.php?f=6&t=3245&start=50#p16998
If you have enough time to read there are some useful user feedbacks and examples at this thread...
riker1
#5 Post by riker1 » 27 Jan 2018, 10:30
ok, thanks
riker1
#6 Post by riker1 » 28 Jan 2018, 13:48
enesbcs wrote: 27 Jan 2018, 09:56
I am trying the bin which was avaiable, but the board is crashing when tcp connections are coming in.
How do I compile this myself ?
Sorry, I am not an expert....
enesbcs
#7 Post by enesbcs » 28 Jan 2018, 19:23
riker1 wrote: 28 Jan 2018, 13:48 How do I compile this myself ?
You can use PlatformIO or Arduino IDE. It takes a lot of work to install and setup everything for the first time.
https://www.letscontrolit.com/wiki/inde ... are_Upload
enesbcs
#8 Post by enesbcs » 28 Jan 2018, 19:38
riker1 wrote: 28 Jan 2018, 13:48 I am trying the bin which was avaiable, but the board is crashing when tcp connections are coming in.
Did you tried the 1M binary? Did your flashing tool confirmed, that your ESP-01 actually have 1MB flash available?
Maybe affected by the ESP-01flashing issues?
https://github.com/letscontrolit/ESPEasy/issues/650
riker1
#9 Post by riker1 » 28 Jan 2018, 19:44
yes I am hit by the PUYA issue
strangwise r147 is running on them, but nothing newer
