New ESP8266 with the size of a Mini Pro
Jopiek
#1 Post by Jopiek » 04 Feb 2018, 22:35
Here you can find a board with the size of an Arduino Mini Pro. It does not have an usb connection so first time flashing with ESP easy is a little of an hassle but when your firmware is around 430kB in size OTA update is possible.
https://www.aliexpress.com/item/3273379 ... 98744.html
Jopiek
Re: New ESP8266 with the size of a Mini Pro
#2 Post by Jopiek » 04 Feb 2018, 22:44
For flashing you will need a UART module.
For flash mode:
EN Pull up to V+
IO15 Pull down to GND
IO0 Pull down to GND
For running ESPEasy:
EN Pull up to V+
IO0 Pull up to V+
Yoda
#3 Post by Yoda » 15 Feb 2018, 17:53
Nice small card, watch for the 5v. connection, it's missing in the text.
Maybe 3.3 means power input.
But anyway, there is a 3.3v regulator on the board.
Robotdyne is until now the only supplier, as far as I can see.
Jopiek
#4 Post by Jopiek » 15 Feb 2018, 18:59
It has a VIn for 4-9V powersupply. The onboard voltage regulator takes it down to 3.3V. I use the 3.3V pin and supply power with 2 x 2000mAh Nimh batteries through a step up converter. The onboard regulator I have taken of to limit power consumption during deep sleep.
Users browsing this forum: Anthropic Claude Bot [bot] and 11 guests
