rules delay to post vcc on deepsleep
rene9900
#1 Post by rene9900 » 10 Feb 2018, 23:23
i have a eps8266-01 running ESPEASY 120, red led cut off for lowest power consume possible, it wake up on reset, and i ordered some LIPO's on ebay, want to try see how long it runs on battery. problem i have now is to make it publish VCC waking up then going to sleep, it works perfect if deep sleep is disabled but not if it is on, then all it publish is the online message, i made rules for delaying the boot so it has time to read the vcc correct..this is my rule set, can any of you locate the "problem"?
Re: rules delay to post vcc on deepsleep
#2 Post by TD-er » 10 Feb 2018, 23:37
Perhaps %vcc% returns something with a space in it?
In my tests, I do not have had a prefix '/' in the topic:
Publish %sysname%/status,blah
So please test also with a simple string instead of %vcc% to eliminate the problem.
rene9900
#3 Post by rene9900 » 10 Feb 2018, 23:50
i dont know if there is a difference from the rules if deepsleep is enabled or not? it publish perfectly vcc to my mqtt broker if deepsleep is disabled?
#4 Post by TD-er » 10 Feb 2018, 23:54
Maybe vcc is not yet present when recovering from deep sleep?
Then it is an empty message.
rene9900
#5 Post by rene9900 » 11 Feb 2018, 00:00
might be, but is there some way around this? what do others do? :(
#6 Post by TD-er » 11 Feb 2018, 00:17
Just by looking at the code, it seems the value for vcc is only updated every 30 seconds. (and right after initTime(), but before a call to process the rules with "System#Boot" as event)
So as a test, you can set the initial 8 seconds to 38 seconds?
Just to see if the value is then updated.
You could move the publish vcc rule to the first block?
rene9900
#7 Post by rene9900 » 11 Feb 2018, 00:35
i try change to 38 sec and still no vcc, log from node red:
11/2/2018 00.25.18node: 5435f871.00fb68
/8266-2/status : msg.payload : string[13]
"8266-2_Online"
11/2/2018 00.25.40node: 5435f871.00fb68
/8266-2/status : msg.payload : string[15]
"Connection Lost"
seems like it wont wait 38sec untill sleep :S
if i set the online publish in the delay it also stop publishing, but if i delete delay it publish vcc -1.0
Domosapiens
#8 Post by Domosapiens » 11 Feb 2018, 00:38
what do others do?
Connect Vcc to the A0 analog port
If you use Wemos D1 (has an internal 220K/100K divider):
Connect Vcc to the A0 analog port via a 100KOhm resistor
By adding a 100k , total resistance is 100k+220k+100k=420k.
So if the Voltage of a fully loaded Cell would be 4.2 Volt, the ADC of the ESP8266 would get 4.2 * 100/420= 1 Volt,
will give a Raw reading of 1023.
The True voltage then can be calculated by: voltage = AnalogRead(A0) * 4.2/1023;
Calibrate for a more accurate reading.
Create a Analog input Task with delay of 1 sec.
Then a rule, something like
On Analog#value do
Publish ..
Sleep
EndOn
With a Soshine 3.7V 3400mAh 18650 battery, the Wemos D1 with battery shield can run for approx. 10hr
rene9900
#9 Post by rene9900 » 11 Feb 2018, 00:55
i would connect A0 but it is a esp8266-01 i'm using, i only have a few pins :)
Domosapiens
#10 Post by Domosapiens » 11 Feb 2018, 00:57
Sorry, overlooked that
#11 Post by TD-er » 11 Feb 2018, 13:16
Did you also try to move the 2nd Publish line right after the first Publish line?
Thus in the event of reboot, not the event triggered by a timer.
rene9900
#12 Post by rene9900 » 11 Feb 2018, 17:47
im not sure i understand how you mean after the first publish? seperated by comma or :?: :?:
On System#Boot do
timerSet,1,12
On Rules#Timer=1 do
Publish /%sysname%/status,%sysname%_Online , Publish /%sysname%/VCC/VCC,%vcc%
#13 Post by grovkillen » 11 Feb 2018, 17:56
rene9900 wrote: 11 Feb 2018, 17:47 im not sure i understand how you mean after the first publish? seperated by comma or :?: :?:
On System#Boot do
timerSet,1,12
On Rules#Timer=1 do
That should be
On System#Boot do
 timerSet,1,12
On Rules#Timer=1 do
 timerSet,1,12
#14 Post by TD-er » 11 Feb 2018, 18:13
No I meant:
On System#Boot do
But GrovKillen is the one to rules them ESP's. So if my suggestion is bogus, please say so :)
rene9900
#15 Post by rene9900 » 11 Feb 2018, 18:17
I noticed that in arduino IDE the VCC do get reported before sleep, but not as MQTT..
ill try change the rules to the ones you suggested thank you :)
INIT : Booting Build nr:120
IP : Static IP :192.168.1.13
WIFI : Connecting... 1
WIFI : Connected!
MQTT : Connected to broker
Subscribed to: /8266-3/#
INIT : Boot OK
INIT : Deep sleep enabled
INIT : Reboot from deepsleep
EVENT: System#Boot
ACT : timerSet,1,12
SYS : 3.45
EVENT: VCC#VCC=3.45
Enter deep sleep...
Domosapiens
#16 Post by Domosapiens » 11 Feb 2018, 18:44
VCC#VCC=3.45
IIRC
Rules don't like Taskname and Value name the same
rene9900
#17 Post by rene9900 » 11 Feb 2018, 19:21
TD-er wrote: 11 Feb 2018, 18:13 No I meant:
On System#Boot do
your rules made this come out in my IDE, SYS sees the vcc but mqtt payload still say -1.00
EVENT: System#Boot
ACT : timerSet,1,12
ACT : Publish /8266-3/status,8266-3_Online
ACT : Publish /8266-3/VCC/VCC,-1.00
MQTT : Topic: /8266-3/status
MQTT : Payload: 8266-3_Online
MQTT : Topic: /8266-3/VCC/VCC
MQTT : Payload: -1.00
SYS : 3.46
EVENT: VCC#VCC=3.46
Enter deep sleep...
rene9900
#18 Post by rene9900 » 11 Feb 2018, 19:26
Domosapiens wrote: 11 Feb 2018, 18:44
VCC#VCC=3.45
IIRC
just changed it but the result is the same :(
EVENT: System#Boot
ACT : timerSet,1,12
ACT : Publish /8266-3/bat/VCC,-1.00
MQTT : Topic: /8266-3/bat/VCC
SYS : 3.46
EVENT: bat#VCC=3.46
Enter deep sleep...
Domosapiens
#19 Post by Domosapiens » 11 Feb 2018, 20:38
Does this helps?
On bat#VCC do
 Publish /%sysname%/bat/VCC,%vcc%
rene9900
#20 Post by rene9900 » 11 Feb 2018, 21:50
Domosapiens wrote: 11 Feb 2018, 20:38 Does this helps?
On bat#VCC do
still no vc post after online publish it go back to deepsleep :(
budman1758
#21 Post by budman1758 » 12 Feb 2018, 04:17
Does this apply here?
https://www.letscontrolit.com/wiki/inde ... _Variables
Note the part about a custom compiled firmware?
rene9900
#22 Post by rene9900 » 12 Feb 2018, 07:50
budman1758 wrote: 12 Feb 2018, 04:17 Does this apply here?
i did enable vcc by "true" before uploading to my 8266, and it does post vcc in every boot, as long as it is not from deepsleep, then it go to sleep before reading vcc, so it post only value of -1.00
This is arduino IDE serial output on normal boot :
WIFI : Connected!
INIT : Boot OK
INIT : Normal boot
EVENT: System#Boot
ACT : timerSet,1,8
EVENT: Clock#Time=Mon,07:45
EVENT: Rules#Timer=1
ACT : On bat#VCC do
ACT : Publish /8266-3/bat/VCC,3.46
MQTT : Payload: 3.46
WD : Uptime 0 ConnectFailures 0 FreeMem 25432
This is Arduino IDE serial output with deepsleep enabled:
WIFI : Connected!
INIT : Boot OK
EVENT: System#Boot
ACT : timerSet,1,12
SYS : 3.46
EVENT: bat#VCC=3.46
Enter deep sleep...
this is my enabled rules:
On System#Boot do
timerSet,1,12
On Rules#Timer=1 do
On bat#VCC do
as serial show, the vcc publish part is ignored for some reason?
budman1758
#23 Post by budman1758 » 12 Feb 2018, 08:10
Just for the hell of it have you tried turning deepsleep off and wait to see if VCC publishes at all? On boot and wake from sleep are different I imagine. Maybe it needs at least 60 seconds or so.
I'm just throwing stuff against the wall to see if anything sticks... :geek:
#24 Post by grovkillen » 12 Feb 2018, 08:31
budman1758 wrote: 12 Feb 2018, 08:10 Just for the hell of it have you tried turning deepsleep off and wait to see if VCC publishes at all? On boot and wake from sleep are different I imagine. Maybe it needs at least 60 seconds or so.
+1
Good thinking Bud!
budman1758
#25 Post by budman1758 » 12 Feb 2018, 08:57
I am wondering now what (if any) difference there is between "systemboot" and "wake from deepsleep" I think you may need a rule that fires when "wake from sleep" happens.
I noticed when I was watching the serial monitor on level 4 when I was testing my keypad app that only "some" system variables were called out in the log on a minute by minute basis. For instance, the ONLY time I ever saw the IP of the unit was on boot. Never saw it at all after that. Matter of fact I believe I only saw "time" and "uptime" regularly. Perhaps "vcc" is like that, only at boot.
Maybe it would work better set up as a regular task. Then you can control the delay time directly.
Hope some of my musings are helpful.
Alpensepp
same problem, no VCC data after awakening from deep sleep
#26 Post by Alpensepp » 12 Feb 2018, 09:41
Same problem here...
I use a ESP8266-12 and a BME280 Sensor with ESPEasy_mega-20180209.
The 8266 ist put in deep sleep, awakes every 300s and sends the BME280 data - perfect.
Now I started to use the ADC input to monitor the battery voltage. It works fine when the 8266 is awake all the time, but no ADC data is sent when awakening from deep sleep. The data from the BME280 is sent.
Any ideas?
best regards
Martin
rene9900
#27 Post by rene9900 » 12 Feb 2018, 10:23
i try changing my delay to 60 in rules like this:
On System#Boot do
timerSet,1,60
On Rules#Timer=1 do
On bat#VCC do
the result is that it do not wait 60 sec from deepsleep wakeup, but go straight to sleep after the boot message ignoring vcc again..
on ordinary boot with no sleep it do wait 60 sec then post vcc....
im clueless by now :S
WIFI : Connected!
INIT : Boot OK
EVENT: System#Boot
ACT : timerSet,1,60
SYS : 3.45
EVENT: bat#VCC=3.45
Enter deep sleep...
#28 Post by grovkillen » 12 Feb 2018, 10:32
Please post all your setup using (if you want) my webdumper?
rene9900
#29 Post by rene9900 » 12 Feb 2018, 10:50
grovkillen wrote: 12 Feb 2018, 10:32 Please post all your setup using (if you want) my webdumper?
i would but how? my mac can not run exe files :)
i tried adding Publish /%sysname%/Time,%systime%
within the timer1,10 event
the systime also do not get reported with sleep enabled..
if i put them all in rules before the timer the Console output do get systime and vcc but without any usable values, i get that the ntp need some secs to grab the time, and guess it is the same issue
with vcc reading, but how do i make a timer that holds deepsleep untill the unit has posted a reading?
EVENT: System#Boot
ACT : Publish /8266-3/VCC,-1.00
ACT : Publish /8266-3/Time, 0:00
ACT : timerSet,1,10
NTP : NTP sync requested
NTP : NTP send to 192.36.143.130
NTP : NTP replied!
MQTT : Topic: /8266-3/Time
MQTT : Payload: ,0:00
SYS : 3.46
EVENT: #VCC=3.46
Enter deep sleep...
state: 5 -> 0 (0)
rm 0
del if0
usl
#30 Post by grovkillen » 12 Feb 2018, 12:03
https://www.letscontrolit.com/wiki/index.php/SleepMode
Note that its recommended to set the Message Delay to 0 in the advanced settings page, since you want the unit to broadcast messages asap in order to save precious battery power.
Have you done this?
rene9900
#31 Post by rene9900 » 12 Feb 2018, 12:37
grovkillen wrote: 12 Feb 2018, 12:03 https://www.letscontrolit.com/wiki/index.php/SleepMode
Have you done this?
yes the message delay in advanced and the delay in devices on the VCC is both on 0
but on the wiki it say :
It will send all the sensor-readings at once (delays are ignored, except for Message Delay at the advanced settings page)
#32 Post by grovkillen » 12 Feb 2018, 12:57
rene9900 wrote: 12 Feb 2018, 12:37
Have you done this?
You're right. Maybe open a issue on Github?
rene9900
#33 Post by rene9900 » 12 Feb 2018, 13:32
grovkillen wrote: 12 Feb 2018, 12:57
i know not how :)
only way it works is by shortcutting positive and negative to coldboot it then it works . besides the missing delay
WIFI : Connected!
INIT : Boot OK
INIT : Cold Boot
EVENT: System#Boot
ACT : timerSet,1,10
NTP : NTP send to 194.239.123.230
NTP : NTP replied!
EVENT: Clock#Time=Mon,13:30
pm open,type:2 0
ACT : Publish /8266-3/VCC,3.45
ACT : Publish /8266-3/Time,13:30
MQTT : Payload: 3.45
MQTT : Payload: 13:30
EVENT: Clock#Time=Mon,13:31
WD : Uptime 0 ConnectFailures 0 FreeMem 25624
SYS : 3.45
EVENT: #VCC=3.45
Enter deep sleep...
Alpensepp
Re: same problem, no VCC data after awakening from deep sleep
#34 Post by Alpensepp » 13 Feb 2018, 09:06
Alpensepp wrote: 12 Feb 2018, 09:41 Hi
Any ideas?
best regards
Martin
I am a step further now.
When I put the ADC/VCC device as the first device in ESPEasy, the data is sent when awakening from deep sleep. But now, the BME280 data is not sent any more.
It seems, like the 8266 is going to deep sleep too fast, and therefore the last (ore later) devices are not able to send their data.
#35 Post by grovkillen » 13 Feb 2018, 10:39
Please raise this issue up Github, referring to this thread.
rene9900
#36 Post by rene9900 » 14 Feb 2018, 10:53
grovkillen wrote: 13 Feb 2018, 10:39 Please raise this issue up Github, referring to this thread.
I made a ticket on github about it.
https://github.com/letscontrolit/ESPEasy/issues/870
#37 Post by grovkillen » 14 Feb 2018, 11:23
rene9900 wrote: 14 Feb 2018, 10:53
Great
Users browsing this forum: Anthropic Claude Bot [bot], Perplexity.ai [bot] and 7 guests
