ESP8266 with DHT22 and seven-segment display
chrissbaumann
#1 Post by chrissbaumann » 14 Feb 2018, 15:22
Hi all,
I have couple of ESPEasy flashed ESP8266s with a temperature/humidity sensor (DHT22) attached to it.
I would now like to attach a 7-segment-display (eg. TM-16372) to the ESP8266 and display either the actual temperature (or humidity, or both alternating), but have no clue how to configure that...
Any advice would be much appreciated.
Many thanks in advance,
Christian
Re: ESP8266 with DHT22 and seven-segment display
#2 Post by grovkillen » 14 Feb 2018, 15:41
Here's a list of supported hardware. More are supported but not yet documented. https://www.letscontrolit.com/wiki/index.php/Devices
chrissbaumann
#3 Post by chrissbaumann » 14 Feb 2018, 18:06
Thanks, I figured out that the TM-16372 is supported, but that wasn´t my question.
My question is about configuration/ setup: What do I need to do, to show temperature and/or humdity, measured by the connected DHT22?
#4 Post by grovkillen » 14 Feb 2018, 18:24
Okay, you need to use rules for that. Please study the tutorials on that. Get back here if you need more help.
Users browsing this forum: Anthropic Claude Bot [bot] and 21 guests
