Good morning,
I did spend some time updating my testnodes tot the mega version 221, 223 and 224 - 4 Mb normal, via the webinterface/update firmware option
After a reboot the node still sends correct data to Domoticz, but i am not able to login anymore via the easy-webconsole, layout top left seems garbled,
or the login screen and button are too high and behind the big menubar as it seems ?
If i give the node a Reset command and cleared config through the arduino serial interface it seems ok first. but failed later with same fault again.
tried a usb flash with version 224-normal-4mb , came up right, uploaded my config.dat backup, rebooted esp , came up right, ip and settings correct , after some time same fault.
tried 2 different machines with linux and win10, 4 different browsers, all the same, went back to mega-220 normal 4 mb and all works ok again.
Only thing that does not work is the bmp180, which seems ok in Easy, gives correct values, sends them out too, but they dont appear in domoticz anymore.
anyone seen this issue ?
Peter
malformed webinterface after version mega-20180220
Forum rules
Re: malformed webinterface after version mega-20180220
Hmm,
Thanks, I probably spent too much time finding out for sure it was not my (browsercache) fault ..
See my temporary work-around to allow you to login: https://github.com/letscontrolit/ESPEas ... -368300365
This will be fixed in the next build.
Login issue was fixed with mega version 27-02-2018, can be closed
