ESP Easy watchdog
tuxmartin
ESP Easy watchdog
#1 Post by tuxmartin » 25 Feb 2018, 23:18
Hi, I'm using Sonoff Basic modules with ESP Easy firmware.
Sometimes Sonoff stop responding to Domoticz and I cannot connect to web interface of espeasy.
I would like to use watchdog. Is it possible?
I found only "watchodog" using ESP easy rules: viewtopic.php?f=4&t=3778&p=21558&hilit=watchdog#p21473
How reliable is it? I would like to use hardware watchodog.
Re: ESP Easy watchdog
#2 Post by TD-er » 26 Feb 2018, 21:48
Do you have an idea on the uptime of the node when it stops responding?
Is it close to 50 days, or more frequently?
And what version of ESPeasy?
tuxmartin
#3 Post by tuxmartin » 26 Feb 2018, 22:40
All modules has "v2.0.0-dev12". One is on Sonoff Basic and second on Wemos D1 Mini.
It is less than 50 days and absolutely random. For example from this year: wemos stoped responding only once, about 30 days uptime. Sonooff stoped responding after about 5-8 hours uptime, after that works about 10 days and again stop responding.
I cannot find any reason.
So if is possible to do hard reboot after module stop responding for defined period it will be great. Something like server send over mqtt "ping" and if espeasy do not receive it for +- 5 minutes than reboot.
#4 Post by TD-er » 26 Feb 2018, 23:08
Could you try to upgrade one to a newer build of ESPeasy?
I've fixed a lot of stability issues.
Perhaps wait for the next build, which will be at 5am tomorrow morning. The build of the 24th had some issues we fixed now.
And also keep a copy of your current settings when you decide to go back (don't think you want to ;) )
