M-Bus water meter (like S0 output)
tuxmartin
#1 Post by tuxmartin » 15 Mar 2018, 13:37
Is there any way how to use the M-Bus module on water meter?
I'm using S0 counter in esp easy for kWh meter, but I cannot find M-Bus support.
M-Bus is standard for water meters.
For example:
https://i.ebayimg.com/00/s/MzJYMzI=/z/4 ... J/$_86.JPG
https://www.mwatechnology.com/products/ ... us-module/
https://www1.itron.com/local/Spain%20Pr ... 14-GAS.pdf
Re: M-Bus water meter (like S0 output)
#2 Post by TD-er » 17 Mar 2018, 11:27
Currently there is no support yet for Mbus.
We're working on Modbus support and I guess Mbus does also has it advantages, since some meters don't support both. (e.g. Eastron has some power meters which only do one or the other)
tuxmartin
#3 Post by tuxmartin » 17 Mar 2018, 13:15
TD-er wrote: 17 Mar 2018, 11:27 Currently there is no support yet for Mbus.
No, it is not Modbus, but M-Bus.
Great news!
When could it be done?
Please look at https://github.com/rscada/libmbus and https://openenergymonitor.org/forum-arc ... /1944.html (message "Submitted by TrystanLea on Fri, 29/05/2015 - 14:40").
#4 Post by TD-er » 17 Mar 2018, 14:30
I know the difference between M-bus and Modbus.
Mbod is more about querying registers on an addressed device.
M-bus is query a device and get a large array of bytes returned representing all values of that sensor.
Both allow to use a number of devices on the same line to be addressable, where M-bus does allow more devices on the same line if I remember correctly.
Not sure if the signal levels are comparable.
You could add an issue for it on Github.
I currently do not have M-bus devices, so I cannot test things and not sure about when I have the time for it, but maybe others do.
