Wifi Setup wizard stuck
Malanow
#1 Post by Malanow » 20 Mar 2018, 20:02
Hello!
I have problem with Wifi setup. When chose network and type password, counter going to zero and I got only this (look at screenshot)
My board is WEMOS D1 mini pro, and I use release ESPeasy mega-20180320.
Board is invisible in the DHCP list on the router. I checked two Wemos board, and two wifi networks. Still does not work:(
Eny ideas why?
Armageddon was yesterday, today we have a serious problem.
Re: Wifi Setup wizard stuck
#2 Post by TD-er » 20 Mar 2018, 21:14
Have you tried to power off and on again?
Malanow
#3 Post by Malanow » 20 Mar 2018, 21:19
Yes, I tried without success.
#4 Post by TD-er » 20 Mar 2018, 21:36
Issue is confirmed, I'm working on a fix now and it will be fixed in the next build tomorrow.
As a short-cut you can try to flash the 0316 build, do initial setup and flash 0320 if you like.
The problem is in the connection test before the settings are being saved.
Malanow
#5 Post by Malanow » 20 Mar 2018, 21:39
Thanks for the information. I am waiting for a new release :):):)
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 9 guests
