I messed up something and want to reinstall everything. I downloaded new firmware, but when I try to flash it, I do not see the new WiFi that I used to connect to this device and connect it to my WiFi.
I found that I have to click and hold flash button while the new firmware is loading, but it did not work for me.
Sometimes I can catch a couple of pings for this device, it means that it still remembers connection and password to my WiFi. I want to wipe it all out and start clean.
I cannot connect to my device at all and cannot reset firmware. Can someone help me with this?
nodeMCU wipe out and start clean
Re: nodeMCU wipe out and start clean
You could connect it via the serial port you use to flash it and then give commands to it via a serial console.
See: https://www.letscontrolit.com/wiki/inde ... _Reference
You can enter "Reset" to return to factory default.
If that doesn't work you can also use a number of flash tools to fully erase the flash chip.
Like this one: https://github.com/espressif/esptool
Thank you for your reply.
Unfortunately, it does not want to listen to any command when I connect to it using COM port.
The tool that you suggested does not have Windows files, but I used esptool.exe that came with the flasher for ESPEasy and it did not help me.
For Python files, you need a Python interpreter.
Instructions on how to run it in Windows: https://www.youtube.com/watch?v=p4UGKRKYFCs
Thank you very much. This worked for me. Strange, do you know why they have the esptool.exe file with all other Windows files?TD-er wrote: ↑20 Mar 2018, 21:06 For Python files, you need a Python interpreter.
Nope, I only used this Python version once, but that was to see whether or not they could identify some ESP chip version and once did test an erase flash.onlize wrote: ↑21 Mar 2018, 02:32Thank you very much. This worked for me. Strange, do you know why they have the esptool.exe file with all other Windows files?TD-er wrote: ↑20 Mar 2018, 21:06 For Python files, you need a Python interpreter.
I've not used it for something else.
Users browsing this forum: Anthropic Claude Bot [bot] and 13 guests
