Recently I started with ESPEASY to see if it can replace my custom made code that I wrote for my project.
I have a ESP (Wemos D1 mini R2) with 2 sensors, DS18B20 and a Thermocouple and 2 LEDs. I'll be using them to measure the temperatures of a swimming pool heater.
Current working setup (with own code):
- DS18B20
- Thermocouple
- 1 colored led that turns on and stays on when the ESP is connected to WiFi
- 1 colored led that blinks when my webserver is doing an HTTP request.
I managed to get the first 3 bullets working with ESPEasy, adding the sensors was easy and I found a Rule on the Wiki to set a GPIO pin to HIGH when connected to WiFi:
on WiFi#Connected do
GPIO,13,1
For the last bullet i need help. My webserver is requesting the JSON output every 10 seconds and stores the values in a database.
Is there any way i can set a GPIO pin to HIGH when the ESP gets a request for about 1 second and then to LOW again, so I can have the LED blink. That way I know the setup is working ok, instead of checking the DB or the ESP logs.
Any help is appreciated.
Set GPIO pin state when an HTTP request is made
Re: Set GPIO pin state when an HTTP request is made
And how your webserver requested data from ESPeasy?
If it send some event command, then in this event set LED gpio on and set some some timer.
On this timer event then set LED gpio off.
Or send pulse to LED gpio.
The webserver requests the URL like this:
<?php
$url = "http://192.168.178.31/json";
$json = file_get_contents($url);
$json_data = json_decode($json, true);
//rest of code
Then I just read the needed values from the array
I checked the syslog, but can't see any incoming event when I execute the script.
<?php
//rest of code
Maybe call something like this:
http://192.168.178.31/control?cmd=event,led_blink
Before or after your http://192.168.178.31/json
and write event "led_blink", which blinks led.
Or send http://<espeasyip>/control?cmd=Pulse,14,1,500
where 14 is GPIO number and 500 are milisecond.
https://www.letscontrolit.com/wiki/inde ... O#Commands
