Rules with system variable
cslehel
#1 Post by cslehel » 02 Apr 2018, 11:55
i have installed 2.0-20180322 on a NodeMCU.
I have two devices, a led and a relay.
I control the led from mqtt, if i turn off the led the relay turns on for a second, then after five seconds the led turns on.
Everything is working except when i reboot the board and connects to the mqtt server, the led turns off and the relay board turns on.
I tried to disable the first command with system variables but without success.
On System#Boot do
  gpio,2,0
On led#state do
  If %uptime%>2
    If [led#state]=1
      LongPulse_mS,5,0,500
      timerSet,1,5
      gpio,5,1
    Endif
  Endif
On Rules#Timer=1 do
  gpio,2,0
  gpio,5,1
The led have Inverse logic checked, Mqtt retain message checked, Send boot state checked, Send to controller checked.
The %uptime%>2 does not seems to work.
Someone have any idea how to disable the first switch after the reoot ?
Thank you.
Re: Rules with system variable
#2 Post by grovkillen » 02 Apr 2018, 12:07
Multiple ifs is not working. Please study the wiki on rules.
cslehel
#3 Post by cslehel » 02 Apr 2018, 12:14
Thank you :)
Users browsing this forum: Anthropic Claude Bot [bot] and 11 guests
