Status of the switch when the power is turned off
BuddhaZen
#1 Post by BuddhaZen » 07 Apr 2018, 14:37
Hi, ESP firmware - mega-20180407. I created a SWITCH, the option - Send Boot state - activated. If the power supply ESP is missing, Domoticz does not determine the status of the switch. When the power ESP is turned on, the SWITCH will be turned off, and Domotics can show the old information that the SWITCH is ON. How to fix it?
hans65
Re: Status of the switch when the power is turned off
#2 Post by hans65 » 08 Apr 2018, 08:17
Have you tried with a dummy variable?
toffel969
#3 Post by toffel969 » 08 Apr 2018, 12:19
BuddhaZen wrote: 07 Apr 2018, 14:37 Hi, ESP firmware - mega-20180407. I created a SWITCH, the option - Send Boot state - activated. If the power supply ESP is missing, Domoticz does not determine the status of the switch. When the power ESP is turned on, the SWITCH will be turned off, and Domotics can show the old information that the SWITCH is ON. How to fix it?
Which gpio are you using? Gpio 0,2,15 have fixed boot states that could be a src of error.
Alternatively you could add a rule to send device state manually after boot.
vbs
#4 Post by vbs » 08 Apr 2018, 12:59
toffel969 wrote: 08 Apr 2018, 12:19 Alternatively you could add a rule to send device state manually after boot.
Sorry, newbie here. How could I do this?
I am using an "FHEM HTTP" Controller and would also like try sending boot state manually. In the documentation (https://www.letscontrolit.com/wiki/inde ... _Reference) I have only found the commands "Publish" and the "Send*"-Commands but they seem either MQTT-only or to other ESPs or raw HTTP requests.
Any other way to force sending of the current value to the configured controller?
I have also tried something like this:
on System#Boot do
     TaskValueSet 1,1,0
     TaskRun 1
Thank you
BuddhaZen
#5 Post by BuddhaZen » 09 Apr 2018, 09:28
toffel969 wrote: 08 Apr 2018, 12:19 Which gpio are you using? Gpio 0,2,15 have fixed boot states that could be a src of error.
I use GPIO 4. How to create a rule?
toffel969
#6 Post by toffel969 » 09 Apr 2018, 13:13
BuddhaZen wrote: 09 Apr 2018, 09:28
Hi, if using GPIO4, make sure that I2C is deactivated in the hardware tab. I would try that first before going with the rule.
The rules (first need to be activated under advanced tab):
On system#boot do
timerset,1,10
On Rules#Timer=1 do
TaksRun,1 //(assuming the input switch device is on Task 1)
BuddhaZen
#7 Post by BuddhaZen » 09 Apr 2018, 13:35
toffel969 wrote: 09 Apr 2018, 13:13 Hi, if using GPIO4, make sure that I2C is deactivated in the hardware tab.
Yep, I2C of course disabled )) Thank you, I will continue to understand this issue further.
UPD:
Solved the problem in this way:
On system#boot do
timerset,1,10
On Rules#Timer=1 do
SendToHTTP [domoticz IP],8080,/json.htm?type=command&param=switchlight&idx=3&switchcmd=Off
The timer is triggered and sends a trip command. By default GIPO4 I pull down to GND.
It's bad that there is no memorization of the current state Switch :(
Users browsing this forum: Bing [Bot] and 15 guests
