SendToHTTP rule
Txus
SendToHTTP rule
#1 Post by Txus » 10 Apr 2018, 14:58
I try to send, from sonoff TH16, upgraded with espeasy 2.0, messages by HTTP (temp & dew)
i would like to are sure that my rule is done. Wireshark isn't log any HTTP message from sonoff to my server.
My rule :
On System#Boot do
timerSet,1,10
On Rules#Timer=1 do
SendToHTTP 192.168.x.x,80,/rcgi.bin/UpdateTagForm?TagName1=T_int_sonoff&TagValue1= [Sonde#Temperature]
timerSet,1,10
Maybe i forget something.
Thank you by advance for your help,
Txus
Re: SendToHTTP rule
#2 Post by TD-er » 10 Apr 2018, 15:04
There is a space in your URL.
Not sure if that's the issue, just noticed it.
ManS-H
Re: SendToHTTP rule
#3 Post by ManS-H » 10 Apr 2018, 16:54
Txus wrote: 10 Apr 2018, 14:58 Hello,
My rule :
On System#Boot do
timerSet,1,10
On Rules#Timer=1 do
timerSet,1,10
Txus
You missed a "," between SendToHTTP and 192.168.x.x,80,
Like this: SendToHTTP,192.168.x.x,80,
Txus
Re: SendToHTTP rule
#4 Post by Txus » 11 Apr 2018, 15:08
Thank you for your answer.
I tryed with a "," between SendToFTP and ip@ with the same result.
Do you know one way to log or monitor TCP output from SONOFF ?
ManS-H
Re: SendToHTTP rule
#5 Post by ManS-H » 11 Apr 2018, 16:14
Txus wrote: 11 Apr 2018, 15:08 Thank you for your answer.
I work with a Wemos with a switch and a Sonoff basic. On the Wemos i used a duo color led for the status of the Sonoff.
On the wemos side:
Devices: Switch input - Switch, name: button1, GPIO 0
on button1#switch do
SendToHTTP,192.168.0.126,80,/control?cmd=Event,ToggleRelay
if [button1#switch]=1 //switch on
gpio,15,0 // red led off
gpio,15,1 // red led on
On the Sonoff side:
Devices: Switch Input, name: Relay, GPIO 12
Rule on the Sonoff side:
Event,togglerelay
on togglerelay do
if [relay#state]=0
gpio,12,1
SendToHTTP,192.168.0.127,80,/control?cmd=GPIO,14,1 // green led controller on
gpio,12,0
SendToHTTP,192.168.0.127,80,/control?cmd=GPIO,14,0 //green led controller off
Txus
Re: SendToHTTP rule
#6 Post by Txus » 11 Apr 2018, 16:42
With the V2.0 ?
ManS-H
Re: SendToHTTP rule
#7 Post by ManS-H » 11 Apr 2018, 17:26
Txus wrote: 11 Apr 2018, 16:42With the V2.0 ?
Wemos: GIT version: v2.0.0-dev13
Sonoff Pow: GIT version: (custom)
Txus
Re: SendToHTTP rule
#8 Post by Txus » 12 Apr 2018, 09:06
not better...
I have downloaded to R120 and result is same.
I think than syntax off the message is not understanded by espeasy program : SendToHTTP,192.168.x.x,80,/rcgi.bin/UpdateTagForm?TagName1=T_int_sonoff&TagValue1= [sonde#temperature]
Re: SendToHTTP rule
#9 Post by grovkillen » 12 Apr 2018, 10:02
You could use Fiddler or Wireshark to receive the messages and look if the sent message is correct.
Txus
Re: SendToHTTP rule
#10 Post by Txus » 12 Apr 2018, 15:55
Is the problem. Wireshark don't log any message from sonoff to my server
ManS-H
Re: SendToHTTP rule
#11 Post by ManS-H » 12 Apr 2018, 16:52
Txus wrote: 12 Apr 2018, 09:06 not better...
maybe a stupid question, but what is this: /rcgi.bin/UpdateTagForm?
Can be that that's your problem?
Txus
Re: SendToHTTP rule
#12 Post by Txus » 12 Apr 2018, 22:28
This command is done when she's sended directly by firefox :roll:
sentinel
Re: SendToHTTP rule
#13 Post by sentinel » 21 May 2018, 13:02
did you sort this out?
the SendToHTTP command doesn't have a comma ',' after the command. See the wiki.
If you install wireshark and apache on your computer, you can perhaps try to send the command to your computer's IP. And then use wireshark to see the command. Or try sending a simpler command with ESPEasy to your computer (eg. SendToHTTP 192.168.x.x,80,/simple)
Did you correct the space TD-er noticed?
Users browsing this forum: Ahrefs [Bot] and 4 guests
