SendToHTTP rule
SendToHTTP rule
I try to send, from sonoff TH16, upgraded with espeasy 2.0, messages by HTTP (temp & dew)
i would like to are sure that my rule is done. Wireshark isn't log any HTTP message from sonoff to my server.
My rule :
On System#Boot do
timerSet,1,10
On Rules#Timer=1 do
SendToHTTP 192.168.x.x,80,/rcgi.bin/UpdateTagForm?TagName1=T_int_sonoff&TagValue1= [Sonde#Temperature]
timerSet,1,10
Maybe i forget something.
Thank you by advance for your help,
Txus
My rule :
On System#Boot do
timerSet,1,10
On Rules#Timer=1 do
timerSet,1,10
Txus
Re: SendToHTTP rule
There is a space in your URL.
Not sure if that's the issue, just noticed it.
Re: SendToHTTP rule
You missed a "," between SendToHTTP and 192.168.x.x,80,Txus wrote: ↑10 Apr 2018, 14:58 Hello,
My rule :
On System#Boot do
timerSet,1,10
On Rules#Timer=1 do
timerSet,1,10
Txus
Like this: SendToHTTP,192.168.x.x,80,
Re: SendToHTTP rule
Thank you for your answer.
I tryed with a "," between SendToFTP and ip@ with the same result.
Do you know one way to log or monitor TCP output from SONOFF ?
Re: SendToHTTP rule
I work with a Wemos with a switch and a Sonoff basic. On the Wemos i used a duo color led for the status of the Sonoff.
On the wemos side:
Devices: Switch input - Switch, name: button1, GPIO 0
on button1#switch do
SendToHTTP,192.168.0.126,80,/control?cmd=Event,ToggleRelay
if [button1#switch]=1 //switch on
gpio,15,0 // red led off
gpio,15,1 // red led on
On the Sonoff side:
Devices: Switch Input, name: Relay, GPIO 12
Rule on the Sonoff side:
Event,togglerelay
on togglerelay do
if [relay#state]=0
gpio,12,1
SendToHTTP,192.168.0.127,80,/control?cmd=GPIO,14,1 // green led controller on
gpio,12,0
SendToHTTP,192.168.0.127,80,/control?cmd=GPIO,14,0 //green led controller off
Re: SendToHTTP rule
not better...
I have downloaded to R120 and result is same.
I think than syntax off the message is not understanded by espeasy program : SendToHTTP,192.168.x.x,80,/rcgi.bin/UpdateTagForm?TagName1=T_int_sonoff&TagValue1= [sonde#temperature]
Re: SendToHTTP rule
You could use Fiddler or Wireshark to receive the messages and look if the sent message is correct.
Re: SendToHTTP rule
Is the problem. Wireshark don't log any message from sonoff to my server
Re: SendToHTTP rule
maybe a stupid question, but what is this: /rcgi.bin/UpdateTagForm?
Can be that that's your problem?
Re: SendToHTTP rule
This command is done when she's sended directly by firefox
Re: SendToHTTP rule
did you sort this out?
the SendToHTTP command doesn't have a comma ',' after the command. See the wiki.
If you install wireshark and apache on your computer, you can perhaps try to send the command to your computer's IP. And then use wireshark to see the command. Or try sending a simpler command with ESPEasy to your computer (eg. SendToHTTP 192.168.x.x,80,/simple)
Did you correct the space TD-er noticed?
Users browsing this forum: Ahrefs [Bot] and 4 guests
