Deep Sleep Button Setup
makefu
#1 Post by makefu » 14 Apr 2018, 23:21
for a project of mine i wanted to add a esp8266 to a "bullshit" button which should trigger an event (http) on every reset. The Button connects RST to GND. Then, for like 30 seconds the the LED should blink.
This is what i came up with with the espeasy rules engine:
# dummy device "dummy" with "counter"(1) and "end"(2)
# led on gpio5
On WiFi#Connected do
  TaskValueSet,2,2,0
  timerSet,1,1
  # or notify 1
  SendToHTTP 192.168.8.2,80,/cgi-bin/suspend
On Rules#Timer=1 do
  if [dummy#counter]=0
    TaskValueSet,2,1,1
   TaskValueSet,2,1,0
  gpio,5,[dummy#counter]
  TaskValueSet,2,2,[dummy#end]+1
  if [dummy#end]!=60
   timerSet,1,1
    deepSleep,0
Everything works correctly but for some reason it is not possible to deepSleep an infinite time (until reset is pressed again) via deepSleep,0 command. without the second `else` and no deepSleep command the "will go to sleep after 30 seconds" builtin is also not triggered anymore and i cannot figure out what the problem is.
When i set
deepSleep,5
but do not connect the pin to RST then esp will be somewhat half asleep and use a whopping 0.1mah which quickly drains the batteries.
Anybody had similar issues or found a workaround?
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot], Google [Bot] and 15 guests
