Issue DHT11 ESP-01
miralant
Issue DHT11 ESP-01
#1 Post by miralant » 13 Apr 2018, 13:48
I've buy the module bellow on ALI.
I've loaded EspEasy R120 on the ESP-01 with my FTDI. It works perfectly, I can connect it on my wifi network.
I've try to setup my device with DHT11 but i've NaN value for the 2 measurements.
I've measured with scope on pin 2 of DHT11 and it still has 3,3v. Never low level to ask for DHT11 measurements.
Do you have an idea ?
thanks
miralant
Re: Issue DHT11 ESP-01
#2 Post by miralant » 19 Apr 2018, 10:50
Nobody uses this kind of module ?
#3 Post by grovkillen » 19 Apr 2018, 12:40
Is it a puya memory?
miralant
#4 Post by miralant » 19 Apr 2018, 12:41
puya ?
#5 Post by grovkillen » 19 Apr 2018, 12:47
Please search the forum. A lot has been covered for this issue.
miralant
#6 Post by miralant » 19 Apr 2018, 13:29
ok, puya version is an ESP-01 with puya parts.
I have to check on the module.
miralant
#7 Post by miralant » 19 Apr 2018, 22:29
Yes, you're right. It's a Puya version.
So wath should I do ? There is a specific version of ESPeasy to load ?
#8 Post by TD-er » 19 Apr 2018, 23:19
miralant wrote: 19 Apr 2018, 22:29 Yes, you're right. It's a Puya version.
Yep, there is a special build for nodes with PUYA flash chips.
It has "puya" in the filename.
miralant
#9 Post by miralant » 20 Apr 2018, 09:23
TD-er wrote: 19 Apr 2018, 23:19
Puya version are only in pre-release (probably soon in stable) ?
what is the difference between ESP_Easy_mega-20180420_dev_ESP8266PUYA_1024.bin and ESP_Easy_mega-20180420_dev_ESP8266PUYA_1024_VCC.bin ?
Micha_he
#10 Post by Micha_he » 20 Apr 2018, 12:02
The second one use the internal ADC to digitize the Vcc-Voltage and not the external signal from ADC/TOUT-pin of the ESP8266.
On ESP-01 the ADC/TOUT is not wired to one of the eight connectors.
miralant
#11 Post by miralant » 20 Apr 2018, 12:09
so I have to use
Micha_he
#12 Post by Micha_he » 20 Apr 2018, 12:41
You can use both !
With the first one you can measure a external 0-1V signal, but with ESP-01 you must solder it direct to the (small) ESP-pin !
With the second one (_VCC) you can process the Vcc-voltage with a 'System-Info'-device. But with this firmware you can't measure a external signal on the ADC/TOUT-pin.
miralant
#13 Post by miralant » 20 Apr 2018, 15:54
ok thanks.
I'll try to setup with the new firmware. Thanks for your help
miralant
#14 Post by miralant » 21 Apr 2018, 22:35
So i've uploaded firmware but temperature is really strangely hight!
papperone
#15 Post by papperone » 22 Apr 2018, 09:59
DHT11 (specially chnese clones) are not famous for their accuracy....
miralant
#16 Post by miralant » 22 Apr 2018, 12:46
papperone wrote: 22 Apr 2018, 09:59 DHT11 (specially chnese clones) are not famous for their accuracy....
At this point...it's not famous....it's non-functionnal !
miralant
#17 Post by miralant » 22 Apr 2018, 18:10
In fact I think the design of the board is stupid. The DHT11 measure the température of the ESP-01. I will try do dismount DHT11 and solder it on the other side of the PCB.
koffie
#18 Post by koffie » 07 Aug 2018, 13:41
I've the same issue, high vaules of both temperature and humidity.
Also the output is changing, but not as you would expect.
Did someone solve this?
miralant
#19 Post by miralant » 07 Aug 2018, 13:44
koffie wrote: 07 Aug 2018, 13:41 Hi,
I've remove (5cm far ESP) and replace DHT11 by DHT22. now it works properly.
koffie
#20 Post by koffie » 07 Aug 2018, 13:57
OK thanks miralant.
problem is that the temp value is 15 degrees celcius above the real temp.
Thats a big difference between the +/- 2 degrees they should differ.
Did you just replace the DHT11 on the board and reuse the board where the ESP-01 is put on?
miralant
#21 Post by miralant » 07 Aug 2018, 14:01
koffie wrote: 07 Aug 2018, 13:57 OK thanks miralant.
yes exactly DHT22 is connected on the same board but with 5cm wirings
pe1fam
#22 Post by pe1fam » 19 Jan 2019, 21:45
Had the same issue here with this very small solution.
Solved it by bending the DHT11 to the outside of its board.
Users browsing this forum: Bing [Bot] and 15 guests
