hi
i have flashed my esp8266 module with the latest version of esp-easy but now it is asking for a web login password and not accepting the default configesp password.
how can i reset the esp8266 module eprom
Esp module not accepting password
Re: Esp module not accepting password
hi,
you need to use a clean flash procedure mentioned here: http://www.esp8266.nu/forum/viewtopic.p ... =466#p2412
Typing ''reset' using the Arduino Serial monitor should also be sufficient to clear all settings.
Another option is to connect RX with TX with a jumpwire, power on the module en disconnect the jumpwire. It should also do a factory reset.
Users browsing this forum: Anthropic Claude Bot [bot] and 12 guests
