Measuring Battery volts ESPEasy Mega
OzGrant
#1 Post by OzGrant » 22 May 2018, 09:12
G'day,
Have seen a few google answers, where DEVICE is set to Analogue Input.
But I do not see that choice. I do see P025, P059, P007, and P002.
Does a PXXX for a simple analogue on A0, have to be imported/configured in some way.
danmero
Re: Measuring Battery volts ESPEasy Mega
#2 Post by danmero » 22 May 2018, 12:50
Build 120 is too old.
See image attached below, my setup on Mega for voltage up to 19V.
Compile your own from source or try the latest nightly built from GitHub
Regards,
Edit: I add a resistor(don't remember the value) and a fuse between the car battery and A0 and do the reverse math.
OzGrant
#3 Post by OzGrant » 22 May 2018, 21:29
Tks for our reply.
I downloaded the latest firmware (GIT version: mega-20180522) and Device "Analog Input" not in the drop-down list.
Displayed choices are:
P025 Analog Input ADS1115
P060 Analog Input MCP3221[Testing]
P007 Analog Input PCF8591
P002 Analog Input Internal
#4 Post by grovkillen » 22 May 2018, 22:14
If you use the VCC version you cannot use analog plugin I think?
OzGrant
#5 Post by OzGrant » 22 May 2018, 22:23
Have tried:
ESP_Easy_mega-20180522_dev_ESP8266_4096.bin
ESP_Easy_mega-20180522_normal_ESP8266_4096.bin
ESP_Easy_mega-20180522_test_ESP8266_4096.bin
and
ESP_Easy_mega-20180522_test_ESP8266_4096_VCC.bin
And got the same failed result.
#6 Post by grovkillen » 22 May 2018, 22:27
No analog at all?
OzGrant
#7 Post by OzGrant » 22 May 2018, 22:41
Just the following.
I think one set did not have the Pxxx number, plus a there was [test] after the name when I viewed the drop-down selection menu.
#8 Post by grovkillen » 22 May 2018, 22:49
Analog Input internal is the one that's using the ESP chips internal analog port.
OzGrant
#9 Post by OzGrant » 22 May 2018, 23:03
I thought analog internal is 8266 3v3 supply and not the A0 pin.
danmero
#10 Post by danmero » 22 May 2018, 23:14
Analog Input use A0, but can read up to internal Vcc.
If you want to go higher Vc you will need a resistor between A0 and Vc. If high current is involved please add a very small fuse inline(<=100mA).
Regards,
OzGrant
#11 Post by OzGrant » 22 May 2018, 23:29
Thanks for your help, I got confused with A0 and VCC.
Also, I like your flash programme, so its been a good day all around.
Grant
#12 Post by grovkillen » 23 May 2018, 05:56
:) Great
QSKONE
#13 Post by QSKONE » 24 Jan 2019, 16:46
pls delete
Users browsing this forum: Anthropic Claude Bot [bot], Unknown bot [bot] and 0 guests
