ESP-01 V3 flashing issues
Sprokkie
Re: ESP-01 V3 flashing issues
#51 Post by Sprokkie » 01 Jun 2018, 11:53
hi,
i cannot get it working with domoticz.
flashed the firmware, see the configpages of the esp-01.
use the same settingas with some other esp module's and i cannot get the output switching,
got the correct idx and the gpio-0.
any thoughts ?
#52 Post by grovkillen » 01 Jun 2018, 12:46
You need to connect the switch to ground since GPIO-0 needs to be set to high for boot.
https://www.letscontrolit.com/wiki/inde ... figuration
Or how do you connect it currently?
Sprokkie
#53 Post by Sprokkie » 01 Jun 2018, 14:02
connected it wit jumper wires on a bread board.
the CH_PCD connected with +
it boots because i see the lets controlit easy esp webpage.
it looks like it doesnt understand the command from domoticz : http://172.16.200.230/control?cmd=GPIO,0,1
#54 Post by grovkillen » 01 Jun 2018, 16:36
Yes but how do you connect the switch? Will it (when closed) pull the value on GPIO0 down to ground?
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 22 guests
