comtel
#1
Post
by comtel » 20 Jun 2018, 15:39
I was able to flash the NodeMCU V3 with the ESP firmware
Successfully completed!
Unfortunately, the NodeMCU V3 does not start as an AccessPoint
I am new to the topic
what am I doing wrong?
Hardware:
"NodeMCU V3 ESP8266 ESP-12 E Lua CH340 WiFI WLan IoT 32 Bit microUSB Arduino"
(From a large online shop)
maybe someone has an idea
sorry for my bad english
#2
Post
by grovkillen » 20 Jun 2018, 18:32
You could try my Flasher (link in my signature below).
comtel
#3
Post
by comtel » 20 Jun 2018, 20:30
unfortunately no success
No access point
DONE!
(You may disconnect the unit if you want.)
Flashing done (76.5s).
Start flashing on COM5 (This might take a minute or two...)
#4
Post
by grovkillen » 20 Jun 2018, 21:00
If you then click on "serial monitor", what do you see?
comtel
#5
Post
by comtel » 21 Jun 2018, 19:33
Open serial monitor, COM port is not avaiable
for flashing as long as this connection is open.
I have no connection active
comtel
#6
Post
by comtel » 21 Jun 2018, 19:35
I read that some modules do not work with ESP Easy
comtel
#7
Post
by comtel » 21 Jun 2018, 19:39
Log-File:
######2018-06-21######
#######0.00.025#######
######FLASH INFO######
BIN file: ESP_Easy_mega-20180619_dev_ESP8266_4096.bin
COM port: (COM5) USB-SERIAL CH340
Baud rate: 115200
######POST FLASH######
No post flash information entered...
######FLASH LOG######
[esptool.exe -vv -cd nodemcu -cb 115200 -cp COM5 -ca 0x00000 -cf "C:\Users\XXXX\Desktop\ESP\BIN\ESP_Easy_mega-20180619_dev_ESP8266_4096.bin"]
[21.06.2018 19:36:49] esptool v0.4.12 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
[21.06.2018 19:36:49] setting board to nodemcu
[21.06.2018 19:36:49] setting baudrate from 115200 to 115200
[21.06.2018 19:36:49] setting port from to COM5
[21.06.2018 19:36:49] setting address from 0x00000000 to 0x00000000
[21.06.2018 19:36:49] espcomm_upload_file
[21.06.2018 19:36:49] espcomm_upload_mem
[21.06.2018 19:36:49] setting serial port timeouts to 1000 ms
[21.06.2018 19:36:49] opening bootloader
[21.06.2018 19:36:49] resetting board
[21.06.2018 19:36:49] trying to connect
[21.06.2018 19:36:49] flush start
[21.06.2018 19:36:49] setting serial port timeouts to 1 ms
[21.06.2018 19:36:49] flush complete
[21.06.2018 19:36:49] espcomm_send_command: sending command header
[21.06.2018 19:36:49] espcomm_send_command: sending command payload
[21.06.2018 19:36:49] read 0, requested 1
[21.06.2018 19:36:49] espcomm_send_command: receiving 2 bytes of data
[21.06.2018 19:36:49] Uploading 778016 bytes from C:\Users\Zweiger\Desktop\ESP\BIN\ESP_Easy_mega-20180619_dev_ESP8266_4096.bin to flash at 0x00000000
[21.06.2018 19:36:49] erasing flash
[21.06.2018 19:36:49] size: 0bdf20 address: 000000
[21.06.2018 19:36:49] first_sector_index: 0
[21.06.2018 19:36:49] total_sector_count: 190
[21.06.2018 19:36:49] head_sector_count: 16
[21.06.2018 19:36:49] adjusted_sector_count: 174
[21.06.2018 19:36:49] erase_size: 0ae000
[21.06.2018 19:36:49] setting serial port timeouts to 15000 ms
[21.06.2018 19:36:49] writing flash
[21.06.2018 19:36:57] ................................................................................ [ 10% ]
[21.06.2018 19:37:05] ................................................................................ [ 21% ]
[21.06.2018 19:37:13] ................................................................................ [ 31% ]
[21.06.2018 19:37:21] ................................................................................ [ 42% ]
[21.06.2018 19:37:30] ................................................................................ [ 52% ]
[21.06.2018 19:37:38] ................................................................................ [ 63% ]
[21.06.2018 19:37:46] ................................................................................ [ 73% ]
[21.06.2018 19:37:54] ................................................................................ [ 84% ]
[21.06.2018 19:38:02] ................................................................................ [ 94% ]
[21.06.2018 19:38:06] ........................................ [ 100% ]
[21.06.2018 19:38:06] starting app without reboot
[21.06.2018 19:38:06] espcomm_send_command: sending command header
[21.06.2018 19:38:06] espcomm_send_command: sending command payload
[21.06.2018 19:38:06] espcomm_send_command: receiving 2 bytes of data
[21.06.2018 19:38:06] closing bootloader
[21.06.2018 19:38:06] flush start
[21.06.2018 19:38:06] setting serial port timeouts to 1 ms
[21.06.2018 19:38:06] setting serial port timeouts to 1000 ms
[21.06.2018 19:38:06] flush complete
[2018-06-21 19:38:06] DONE!
[2018-06-21 19:38:06] JOB COMPLETED, over and out!
#8
Post
by grovkillen » 21 Jun 2018, 20:07
Sounds like you try to open it while the flashing is still taking place. Please try it again.
comtel
#9
Post
by comtel » 21 Jun 2018, 21:18
already tried everything. The message is displayed directly
#10
Post
by grovkillen » 21 Jun 2018, 21:48
Still, are you sure nothing is using the com port when you click that button? As in, restart your computer, start the Flasher and click on that button.
comtel
#11
Post
by comtel » 21 Jun 2018, 22:02
everything checked. Windows restarted. same message. usb adapter broken? only have this.
#12
Post
by grovkillen » 21 Jun 2018, 23:30
The USB programer on the board you mean?
comtel
#13
Post
by comtel » 22 Jun 2018, 21:29
I found the problem!
I followed instructions as a beginner.
There was a USB TTL adapter recommended for flashing.
Flashing also worked. However, it did not work then.
Now directly connected via USB, everything works as described.
Thank you for your help!
Users browsing this forum: Anthropic Claude Bot [bot] and 18 guests
