After update from 25/06 to 8/07 release Thingspeak controller updates only write once the data to the thingspeak server.
Tried several reboots cold warm to no avail, réinitialisation of the write key didn’t help either.
ESPEasy_mega-20180708 & Thingspeak no longer friends
Belgium and land of ESP ... counting
Re: ESPEasy_mega-20180708 & Thingspeak no longer friends
Hmm, I was not aware I changed anything that could have this effect.
Is it using default settings and then configure Thingspeak?
Then you could set the MQTT message delay to 1000 msec again. (changed that default to 100 msec)
Please report back if it solves this issue.
I’m always at 120000 just a Temp recording of the cabinet to have an external safeguard to be available.
Tried again this morning with the latest release 10/07 and same result, went back to 25/06 everything OK
120 seconds as MQTT Message Interval? (Tools => Advanced => "Message Interval" )
That will lead to a lot more issues.
The default of that setting used to be 1000 msec, which will result in a freeze of about 1 second of the whole node when sending data.
So that's definitely something I should look into, but for now I set it to 100 msec as default.
But that setting is also used in a number of controllers, so that's why I asked about it.
Just tested with 1000 does not update.
Set to 100msec default It works
Free RAM from Last FW in June to the latest July -2000
Free RAM is something I am looking into.
But using 100 msec as MQTT message delay is now working?
Thingspeak and ESPeasy are friends again with the last builds?
I also merged a fix yesterday regarding the check of values sent to controllers. (sending to Thingspeak is a controller)
Yes everything ok with 100ms thanks
Thanks for the feedback. We're investing the necessity of that setting and all feedback is appreciated.
Users browsing this forum: Bing [Bot] and 4 guests
