Good day all,
Follow me work this Oled command not :
Command
OLEDCMD,<value> on, off, clear
have a nice day
grt. Harald
OLED Display Command Bug ?
Esp Easy user from R76 , think cool, think old school!
Re: OLED Display Command Bug ?
Exactly how do you enter the command. The syntax you shows is not actually the command.
I use on this way the command :
http://192.168.xxx.xxx/control?cmd=oledcmd,on (off / clear)
http://<espeasyip>/control?cmd=<command>,<on> (off /clear)
According to this description :
https://www.letscontrolit.com/wiki/inde ... LEDDisplay
grt. Harald
grt. Harald
And what version are you running?
ohhh, sorry , had forgotten to put the version there
But I have this GIT version mega-20180723 [test].
This bug also does not work with some older GIT version
grt. Harald
grt. Harald
bay the way, I use the "Oled Framed" plugin
There is a difference between OLED framed and "Oled" plugin.
Just use "OLEDFRAMEDCMD" (case doesn't matter for the command itself).
Values are "off", "low", "med", "high".
See https://github.com/letscontrolit/ESPEas ... #L378-L400
okeeeee, that works
then to me that went wrong
Thank you very much !
grt. Harald
grt. Harald
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot], Bing [Bot], opensiteexplorer.org/dotbot [bot] and 18 guests
