I'm new to the world of automation using RFLink. I hope someone can help me with an english or dutch procedure on how to pair Somfy screens using a RFLink.
I'm Using :
Raspberry PI 3 model B
Domoticz
RFLink 433.420 MHZ
What is working is that in Domoticz I can push the button Learn Light switch and it will recognize the Somfy Telis 1 remote when I push a button on this remote.
What doesn't work is controlling the blinds from Domoticz after that. No response from the blinds at all.
I found on this forum and others that you should learn the code of the Somfy Telis remote not in Domoticz but using RFLinkLoader.exe
There is a french procedure telling you how to do this : https://matdomotique.wordpress.com/2016 ... -et-somfy/
I don't speak french and Google translate isn't doing a really good job in translating this article. So unfortunately I still don't understand how to do this.
Can someone please explain me in English or dutch what the procedure is to pair a Somfy blinds using a RFlink. Or maybe refer me to an english procedure that explains how to do this (I couldn't find it
Thanks in advance!
Kind Regards,
Ramon
