Multiple timers running simultaneously?
boolie
#1 Post by boolie » 05 Aug 2018, 21:35
Hi All,
I assume that one reason for having 8 separate timers, is that one can have them running simultaneously to cause things to happen at different intervals. However, it's not working for me if so.
In my boot code, I set two timers: T1 @ 5secs to update a displayed sensor value and T3 @ 60 secs to send the sensor values to a remote server using a HTTP request. When I watch the log, T1 is being set and the event is occurring as expected. There's never any mention of T3 in the log at all and the remote server is not being updated.
Am I doing something wrong, or is ESPEasy not capable of using multiple timers simultaneously?
Full rules code below...
On system#boot
//start timer for temp/hum display cycle
   event,timerstart
On timerstart do
    timerSet,3,60
    timerSet,1,5
    TaskValueSet,12,1,1
On timerstop do
//stop timer
    timerSet,1,0
    timerSet,3,0
On Rules#Timer=1 do
//show temp or hum as determined by "cycle" value of dummy device MyVars
    if [MyVars#cycle] = 1
        7dt,[DHT#Temperature]
    if [MyVars#cycle] = 2
	7dn,[DHT#Humidity]
    if [MyVars#cycle] = 3
	7dt,[DA#Temperature]
    if [MyVars#cycle] = 4
	7dt,[DB#Temperature]
    TaskValueSet,12,1,[MyVars#cycle]+1
    if [MyVars#cycle] = 5
        TaskValueSet,12,1,1
    timerSet,1,5
On Rules#Timer=3
    event,sendtovera
    timerSet,3,60
On sendtovera
    SendtoHTTP 192.168.8.200,80,/port_3480/data_request?id=variableset&DeviceNum=143&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=[DHT#Temperature]
    SendtoHTTP 192.168.8.200,80,/port_3480/data_request?id=variableset&DeviceNum=144&serviceId=urn:micasaverde-com:serviceId:HumiditySensor1&Variable=CurrentLevel&Value=[DHT#Humidity]
    SendtoHTTP 192.168.8.200,80,/port_3480/data_request?id=variableset&DeviceNum=145&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=[DA#Temperature]
    SendtoHTTP 192.168.8.200,80,/port_3480/data_request?id=variableset&DeviceNum=146&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=[DB#Temperature]
On wifi#disconnected
    7dn,0
    event,timerstop
On wifi#connected
    event,timerstart
//EOF
Various D1 & Sonoffs with ESPEasy, some Tasmota. Domoticz, Z-wave.
ESPEasy Patreon - keep up the good stuff, guys!
Re: Multiple timers running simultaneously?
#2 Post by TD-er » 05 Aug 2018, 21:52
You're missing a "do" at the "On Rules#Timer=3"
See: https://www.letscontrolit.com/wiki/inde ... ules#Timer
boolie
#3 Post by boolie » 07 Aug 2018, 17:04
D'oh! How did I miss that? :oops: Thanks TD-er :D
