rules - I need help
woocashewski
rules - I need help
#1 Post by woocashewski » 08 Oct 2018, 17:56
hi,
I need help with rules - I want to send neopixel commands triggered by state of a sensor (integer value).
the problem is (at least for me..), that I need it to work like that:
if [value] <n
than this (this part is easy - command tgiggered by condition)
if [value] is greater than n+1 and smaller than n2
than this
if [value] is greater than n2+1 and smaller than n3
than this
the problem is, that this "n" values are from 0 - 150, so it's /nearly, due to rules size limitation and common sense ;) / impossible to get this working by equality function
eg.
    if [p1#p] < 30
        neopixel,1,0,255,0
    if [p1#p] = 30
        neopixel,1,10,100,0
and so on, from 30 to 150 ;)
maybe I have some brain fog or something, but I can't find how to get this work.
any help?
thanks in an advance.
Re: rules - I need help
#2 Post by grovkillen » 08 Oct 2018, 19:18
On p1#p Do
 If [p1#p]<30
  neopixel,1,0,255,1
 Else
 neopixel,1,([p1#p]*255/150),100,1
 EndIf
Just something I made out of my head. Can't you do something like that?
woocashewski
#3 Post by woocashewski » 08 Oct 2018, 21:21
thank you for a quick response
unfortunately it's not working - values calculated from formula are omitted in command for neopixel - if formula is for red - there's no red at all.
#4 Post by grovkillen » 08 Oct 2018, 22:05
Must be that the neopixel plugin doesn't accept float values. Maybe if you first put them to a dummy value with 0 decimals?
woocashewski
#5 Post by woocashewski » 08 Oct 2018, 22:12
I was thinking about dummy device, but i don't know how to enter data into dummy device, [ and # are not accepted, so... another long night of searching before me ;)
PS. help links related to plugins are veeeery short, and sometimes misleading. Maybe it's time to join community and use my experience.
#6 Post by grovkillen » 08 Oct 2018, 22:43
woocashewski wrote: 08 Oct 2018, 22:12 I was thinking about dummy device, but i don't know how to enter data into dummy device, [ and # are not accepted, so... another long night of searching before me ;)
TaskValueSet,<tasknumber>,<value umber>,<value or formula>
The formula is fairly straightforward, but values are in the syntax [p1#p].
The wiki is being redone (we're moving it to GitHub/ReadTheDocs). It'll get better.
woocashewski
#7 Post by woocashewski » 08 Oct 2018, 23:59
all set :)
thank You for assistance.
Users browsing this forum: Google [Bot] and 15 guests
