Dylantje
#1
Post
by Dylantje » 19 Jan 2016, 00:28
Is there a simple way to set the esp2866 to factory settings?
Or reset him?
I get errors:
PID:0
Version:0
INIT : Incorrect PID or version!
RESET: Reboot count: 4
RESET: To many reset attempts
Entered Rescue mode!
Or what can i do ....?
All my esp bricked, is not possible i gues...
costo
#2
Post
by costo » 19 Jan 2016, 01:27
Martinus suggested some time ago this:
On the ESP connect RX to TX and apply power for a short time. That wll reset it to 'factory settings'
For me that helped when I screwed-up the password to enter the AP on a commercial dimmer with ESP8266 , it set the password back to the factory setting.
If ESP is flashed with ESPEasy this will set all parameters back to the default. Not sure if it will help you but you should try.
Dylantje
#3
Post
by Dylantje » 19 Jan 2016, 09:59
costo wrote:Martinus suggested some time ago this:
Not working
I did a pull up tot gpio0 no succes...
